Real Name: Taylor
Real Name: Taylor
First things first, I would crawl under your truck to make sure your truck is infact pre wired for the factory style lamps. I know most are prewired, but yours being a 2.7L "base" model 4Runner means it is possible the wiring isn't there. You're looking for a small harness taped to the side of your turn signal harness. only two wires go into the fog light harness.
IF you do have the wiring there,
I recommend doing an OEM set up. With the correct bulbs, they put out a nice amount of light. It will run you anywhere from 50-150 bucks for a used set on here (a new set is outrageous!) but the installation is easy. Just bolt in the brackets, add a fog relay and then locate a stalk with the fog switch on it (can be had for aroun 25 bucks), or you can search around on here and find the thread where a member seperated the wiring so they could just use a $5 rocker switch and save themselves some money.
If you don't have the wiring,
opt for a nice set of PIAA or Hella lights. The installation (especially on PIAA's) is extremely simple. They are a little pricier, but you get what you pay for.
I have both factory fogs (with High Output bulbs), a set of PIAA fog lamps and PIAA headlight bulbs and I couldn't be happier. I only want to add some distance driving lamps eventually. Probably more PIAA's or a LED bar.
I hope this helps, and isn't too confusing!
1999 4Runner SR5 Highlander V6 4WD ELocker
2008 Toyota 4Runner LTD V8 4WD
2000 4Runner SR5 V6 4WD- Sold
"Why do people measure life by the years, and not by how good the years were?"
