Old 10-26-2014, 07:21 PM #1
ARC ARC is offline
Real Name: Andrew
ARC is on a distinguished road
ARC ARC is offline
Real Name: Andrew
LCA cams siezed, need help
I know the alignment cams freezing/seizing on these things is common. I am trying get mine out to replace them, but they aren't budging. I have the LCA bolts out but the cams/sleeves are seized to the bushing cups.
Advice?
97 FZJ80 40th Anniversary Edition wife-mobile/weekend wheeler
SOLD'98 T4R 5spd, e-locker, Boss coilovers, LC 8wraps, Tokico blacks, SS extended bump stops, 255/85r16 Toyo M/T's
http://www.toyota-4runner.org/3rd-ge...ml#post1707857
ARC is offline   Reply With QuoteReply With Quote
Old 10-26-2014, 07:38 PM #2
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Advice?
A lot of people end of having to cut them out. You can also use a torch, but you need to be careful that way. By using the torch you only want to heat the metal sleeve. Once you hear it starting to sizzle you can use a punch to push it out.
MStudt is offline   Reply With QuoteReply With Quote
Old 10-26-2014, 07:49 PM #3
ARC ARC is offline
Real Name: Andrew
ARC ARC is offline
Real Name: Andrew
Already tried the torch method to no avail. Unless someone points me in a different direction tonight I plan to cut it with a saws-all tomorrow. I think an air chisel would be better, but I don't have one.
Old 10-26-2014, 07:57 PM #4
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
An air chisel isn't going to get you anywhere. Keep in mind with the torch that you're not trying to melt the rubber from the outside. You need to heat the inside of the bushing so that it melts from the inside out. After about 90-120 seconds the bushings should slide out.
Old 10-26-2014, 08:06 PM #5
ARC ARC is offline
Real Name: Andrew
ARC ARC is offline
Real Name: Andrew
Why wouldn't an air chisel get me anywhere? I have cut lots of bolts with air chisel's before.
And I understand about the heat. After pulling the bolt out I put heat through center of the sleeve until it started popping and then smacked it would a 3lb sledge and it didn't budge. Then I heated it the same way and tried to use the factory jack to press them out. The jack just caused the mounts on the cross member to flex.
Old 10-26-2014, 11:11 PM #6
ARC ARC is offline
Real Name: Andrew
ARC ARC is offline
Real Name: Andrew
Anybody have any tricks for getting the drivers side bolt out passed the steering rack? I currently have the rack free from all of its mounts but still connected.
Old 10-26-2014, 11:22 PM #7
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
there is 1 bolt on the right as well as 1 nut.
there is 1 bolt under the tranny bell housing
there is 1 bolt on the left side.
then the other few nuts and bolts on the steering yoke and the tie rod ends.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 10-26-2014, 11:58 PM #8
ARC ARC is offline
Real Name: Andrew
ARC ARC is offline
Real Name: Andrew
Yes I understand how that. My question was is there a way to get the LCA bolt out without removing the rack? Was hoping to avoid disconnecting the steering. Took all the mounting bolts out of the rack as I am replacing the rack bushings as well.
Need help rear end siezed mschein1 3rd gen T4Rs 12 07-23-2014 10:02 AM
Suggested methods for lower control arm removal (siezed cams) bergs 4th Gen T4Rs 14 01-30-2014 06:11 PM
4th Gen Front Brake Caliper Siezed Chrisygirl17 4th Gen T4Rs 22 06-29-2013 09:32 PM
4th Gen Siezed Brake Caliper- Which Rebuilt? strangec Maintenance/Detailing 13 05-01-2012 02:58 PM
siezed brake caliper chippr Problems & Warranty Issues 1 06-12-2009 01:18 PM
