10-27-2014, 09:41 PM
Cruise Control issue with a 5 speed.
I have had my T4R 5 speed for several years now. I started having issues with the cruise control. I would turn it on, have cruise light up on the dash, but the speed would not set. I take some long trips and use the CC several times a week. It turns out the clutch pedal was not returning all the way up. There are 2 sensors on the clutch and 1 on the brake. They are small white plastic push buttons. I had removed the large clutch spring when I got tired of replacing the plastic bushings that would crack and cause terrible squeaking. At True Value you can buy a #70 barrel spring that will help to hold the clutch pedal up in place. It cost about $3. If you need a stronger spring, buy the brake pedal return spring from a Toyota dealer. I found out about this in the Toyotech forum. My CC works fine now. Thank you fellow posters!
This is from the Toyotech forum:
There is an adjustment for the clutch pedal under the dash. If it is out of adjustment, the cruise control will not engage. Look under there and you will see a small white thing that the clutch pedal pushes on when the pedal is depressed.
Ben
1996 T4R SR5 4wd 5speed manual 3.4 V6
Evergreen Pearl w/ Taupe cloth
265/75 16 BFG AT T/A KO2, E load
297,000+ miles...
10-27-2014, 09:58 PM
Real Name: Charlie
Real Name: Charlie
I have this same issue. Can you post a picture of the spring you added?
Originally Posted by STX4Runner
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
10-27-2014, 10:01 PM
Wow, really good to know, worth a try. My whole assembly has been worn out for a year or so. Always pulling the pedal back to myself with my foot.
2000 4runner: Supercharged, Toytec Coilovers front OME 890s rear, 2" RB BL, 35" Duratracs, Winch, Bumpers.....etc
1980 Pickup: 4.3 Vortec swap, 38" Kevlars, Bumpers and int roll cage etc...Build http://www.pirate4x4.com/forum/toyot...tec-build.html
GO Griz
10-27-2014, 10:53 PM
Real Name: Charlie
Real Name: Charlie
That's how mine is with 250,000 miles. How many miles on yours?
10-28-2014, 08:02 AM
This is exacty the fix I did on mine wich I read about here from someone else's build thread. Except I used a brake pedal spring from an auto Tacoma in a junk yard. Cleared my cruise issues right up. Still occasionally catch myself bump the cutch pedal up with my foot out of habit though.
Apparently the Tacoma's use a linear pull spring for the clutch but Toyota went with a "barrel" spring for the Runner as when the spring is all the way down it actually helps hold the clutch pedal down. Supposed to be for more "luxury" or whatever. I notice not difference with the constantly increasing resistance linear pull vs the "barrel" except for my cruise works.
.::TRD; no, your jeep can't fallow this.
2000 Black 3.4 N/A 5 speed 4x4, most recent mod: OE e-locker setup with 4.30 gears from an auto. ARB front winch plate bumber in the garage.
She's, starting to be less stock, with about 226,428 miles as of 5/27/16.
10-28-2014, 09:36 AM
I added another photo to my original post. I hope this helps.
Ben
297,000+ miles...
10-28-2014, 07:48 PM
My rig is at just under 160,000 so not close to yours, surprised mine has gotten worn out so fast. Thanks for adding the pic!
GO Griz
