Old 11-21-2014, 10:46 PM #16
Squirt's Avatar
Squirt Squirt is offline
Real Name: Shannon
Squirt is on a distinguished road
Squirt's Avatar
Real Name: Shannon
Originally Posted by nissanh View Post
I always go with OEM toyota. Even used TOYOTA parts are far far far superior than any brand new aftermarket part.
Agreed
Squirt is offline   Reply With QuoteReply With Quote
Old 11-22-2014, 11:05 AM #17
Squirt's Avatar
Real Name: Shannon
Squirt's Avatar
Real Name: Shannon
well. You don't happen to have a starter laying around do you...what sites would you suggest I search for an OEM starter? just do not want to go to the dealership and buy one and you know as well as I do that some of these sites that are selling OEM parts are iffy.you're being a great help by the way I do appreciate your input.
Old 11-22-2014, 11:12 AM #18
Squirt's Avatar
Real Name: Shannon
Squirt's Avatar
Real Name: Shannon
Originally Posted by Doc2012 View Post
The slightest thing being off will cause that thing to break.
It constantly rotating, and the forces on it are pretty extreme.
Just it being unbalanced can cause it.
The starter not being shimmed right, close enough for their specs, but not Toyota specs, ect. There's a million things.
suggestions for online sites selling OEM parts that are legit?unless of course you have a starter laying around?
Old 11-22-2014, 11:57 AM #19
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
TRDparts4you IIRC.
Your dealer. I know there's one in Raleigh.
As @nissanh said, I've had some good experience with junk yard starters.
Actually, still running one two years after I swamped my truck.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 11-22-2014, 01:26 PM #20
nissanh nissanh is offline
I got few good used OEM starters.
Old 11-22-2014, 02:45 PM #21
Squirt's Avatar
Real Name: Shannon
Squirt's Avatar
Real Name: Shannon
yeah I have a buddy in the service bay at Leith Toyota but I'm trying to not go the dealership route..even with a friend there still $$$$.
I'll check out TRDparts4you and see what some of the local junkyards have. I appreciate the info I just want it to be all correct so that I don't cause the same problem all over again.
Old 11-22-2014, 08:36 PM #22
NasaE30's Avatar
NasaE30 NasaE30 is offline
Real Name: Zach
NasaE30 is on a distinguished road
NasaE30's Avatar
Real Name: Zach
What noise should we be listening for
2004 4Runner Limited V8 Daystar 2.5/1.5 Cooper AT3 265/70r17 HCF delete Plasti Dipped stock wheels, roof rack and bumpers. RCI aluminum skids.
1999 4runner Limited 3.4 E-locker, 285/75r16 BFG AT, Spidertrax RC lift, deckplate, front end backdate, B&M trans cooler. Group 34/78 Diehard p4 battery
NasaE30 is offline   Reply With QuoteReply With Quote
Old 11-22-2014, 10:39 PM #23
Squirt's Avatar
Real Name: Shannon
Squirt's Avatar
Real Name: Shannon
metallic ticking sound coming from where the engine joins the transmission...you'll hear it at idle and when you take your foot out of it slowing down. gets considerably more audible as the flexplate starts to crack. in the beginning you made a mistake it for a lifter ticking.
Old 07-31-2017, 05:10 PM #24
NBBAZ's Avatar
NBBAZ NBBAZ is offline
NBBAZ is on a distinguished road
NBBAZ's Avatar
Reviving an old thread.
Damn!
I'm pretty sure this happened to my T4R. It started with what sounded like lifter ticking, then got louder over the last few hundred miles. Hear it most while idling or coasting slowly. Goes away in drive or reverse, or even a change of engine load. To make it more frustrating it doesn't always make noise. It's quiet when first started and cold. Usually increases as it gets warm.
Dealer says about $1360 before tax and fees!
Anyone have experience with a dealer doing the work? I like to do a lot of my own work, but I don't have time or a tranny jack.
NBBAZ is offline   Reply With QuoteReply With Quote
Old 07-31-2017, 05:28 PM #25
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Originally Posted by NBBAZ View Post
Damn!
Just an FYI, your symptoms may not point to a cracked starter. They may point to something on the AC compressor. Clutch, belt tensioner bearing, etc.
Mine has been ticking for years, with the same audible symptoms as a cracked starter. Very quiet tick at idle, lessened with any load, etc.
I first suspected my AC when I was driving with the AC button turned off. This lets the clutch freewheel and not engage the compressor. It was dead quiet, no tick. I confirmed it by flat out removing the AC belt for a couple days and it was absolutely tick-less.
My AC still blows hard and ice-cold and the compressor is a PITA to replace from what I've read (proprietary tools to properly evacuate/recharge the refrigerant, etc), so I'll just let it go till it blows completely.
FWIW
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 07-31-2017, 05:34 PM #26
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
FWIW
I think he had dealer diagnose it. Its pretty easy diagnosing the flexplate. You can usually see it cracked.
If its the starter not disengaging all the way I'm sure they would have have diagnosed that issue and not quoted him labor of removing a transmission.
JayRolla is offline   Reply With QuoteReply With Quote
Old 07-31-2017, 07:36 PM #27
19963.4lsr5 19963.4lsr5 is online now
Every time I cracked a flex plate on the CJ it sounded likes rod Knock that got louder under load. After the 2nd one I figured out the alignment dowels were missing.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 02-24-2020, 06:40 PM #28
JAMs97T100 JAMs97T100 is offline
JAMs97T100 is on a distinguished road
Talking 97 T100 Flexplate issue
Whats up fellas. New to the chat and digging all the info I read on here often. Well its my turn on the Flexplate issue.
I have a 97 T100 3.4l V6 (5VZ-FE) 4x4 and shes a beaut. Doing all the R&R with my 12yr son and its all his by the time were done. Now, on to the Flexplate issue, we will be tackling this job tomorrow 2-25-2020, and am kinda excited. First trans drop for myself yet have preped with forums and videos. I do have all the tools we'll need (got to buy a few new ones for the fun of it) and mechanical ability, just still looking for Torque Specs on the Flexplate bolts. Bought the Chilton and Haynes yet nothing exact on this matter. Unless I read past it? Either way, any heads up or help on thos would be appreciated! JAMs97T100 thanks you much
JAMs97T100 is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 07:56 PM #29
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
you can grab the FSM here
Complete 4Runner Service Manual 1996-2002.pdf - Google Drive
in the section
AUTOMATIC TRANSMISSION UNIT (A340F)
should have all the N·m (kgf·cm, ft·lbf) specs
TC to flex plate Torque: 41 N·m (420 kgf·cm, 30 ft·lbf)
you sound like your good to go and well prepared. maybe read the entire section on the removal? I had 97 T100 for 20 years... was a great truck. I would think the 4runner FSM should be pretty similar to the T100.
good luck, post some shots of the carnage once your done.
Old 02-24-2020, 09:12 PM #30
JROTN JROTN is offline
JROTN is on a distinguished road
Flexplate
Be sure the dowel pins (2) are in the engine block (as stated in post #27) where the bell housing and engine meet! I worked on transmissions for a number of years and changed many flex plates. If the trans has been pulled before and swapped out then the dowel pins can be stuck in the old trans and the person doing the R+R may not notice they were stuck in the trans. Thus installing the new trans without dowels being in the block.
JROTN is offline   Reply With QuoteReply With Quote
Flexplate replacement - any advice? napstermike 3rd gen T4Rs 9 07-09-2014 02:15 AM
Bolts on torque converter/flexplate DPR64 3rd gen T4Rs 2 01-11-2014 05:31 PM
Plastidip nightmare. calcrc 5th gen T4Rs 40 05-05-2013 02:26 PM
An axle nightmare. michael833 3rd gen T4Rs 6 09-28-2011 02:33 PM
Nightmare Brake Job KrazedJD 4th Gen T4Rs 10 03-22-2011 11:07 PM
