Old 11-22-2014, 10:14 PM #1
Kenworth Kenworth is offline
Kenworth is on a distinguished road
Power steering issue
When we start are 99 t4r power steering fluid starts leaking out around fill cap
I replaced cap but fluid is still forcing its way past cap seal,after car warms up it seems fine,any ideas? Must be a bypass valve on pump that's not working when cold?
Kenworth is offline   Reply With QuoteReply With Quote
Old 11-23-2014, 12:16 AM #2
snow junky's Avatar
snow junky snow junky is offline
snow junky is on a distinguished road
snow junky's Avatar
Normally it does that when it's over filled.
97 4runner 3rzfe 5speed
D44 sky mfg sas
Dual transfer cases
toyo 37s 5.29 locked F&R
York OBA compressor
snow junky is offline   Reply With QuoteReply With Quote
Old 11-23-2014, 02:23 AM #3
It was low, and nothing add for a long time
Old 11-23-2014, 01:42 PM #4
nissanh nissanh is offline
Any chance of trapped air? How old the oil in the pump? if it is old, I'll suggest remove old oil in the pump and refill with fresh oil. Start the truck, turn wheel from lock to lock slowly and turn off the engine. Remove oil in the reservoir and refill fresh oil. Repeat few times.
Old 11-23-2014, 05:44 PM #5
System was flushed a few months back when a new pump was installed?
Only happens when cold , when oil is coming out its really aerated /foamy ?
Old 11-23-2014, 06:20 PM #6
AZ4Running's Avatar
AZ4Running AZ4Running is offline
Real Name: Neal
AZ4Running is on a distinguished road
AZ4Running's Avatar
Real Name: Neal
Sounds like air in the system. If the ps fluid is foamy then there is air in ther for sure. Fill res and start motor, turn t he wheel left to right all way several times, shut off and check fuild level. Repeat until no more foam and not over flowing. Fyi toyotas take aft fluid in the ps not normal ps fluid but os fuild will work.
AZ4Running is offline   Reply With QuoteReply With Quote
Old 11-27-2014, 05:46 PM #7
Problem fixed today installed 2nd rebuilt pump from advanced auto,
Only thing I see with pump was shaft /bearing was loose with a lot of up and down play compared to new pump maybe sucking air ? Anyhow it's fine for now
See if it lasts.
1st gen power steering issue Dibs01 Classic T4Rs 10 12-13-2014 09:04 AM
Power Steering Issue SR587 Classic T4Rs 8 02-15-2014 01:50 PM
Power Steering/Brake issue. Cpl_Tobz Classic T4Rs 7 01-18-2013 08:55 PM
Power steering issue 93runnerguy Classic T4Rs 16 10-04-2011 09:51 PM
Power Steering Issue rtuck1 4th Gen T4Rs 1 06-27-2011 03:25 PM
