Old 03-21-2019, 02:54 AM #271
Kryptoroxx's Avatar
Kryptoroxx Kryptoroxx is offline
Real Name: John
Kryptoroxx has a spectacular aura about Kryptoroxx has a spectacular aura about
Kryptoroxx's Avatar
Real Name: John
Originally Posted by fightman80 View Post
Came over here from Facebook as promised... can't see your tire carrier pics for some reason....
Judging from the comments... sounds like you did all the right improvements. As you said in your previous posts... props to Thorrider for trying it... and showing us how NOT to do it.... It made it possible for us to learn from his mistakes, and improve the design.
I am not 100% what is going on with that. I uploaded them all to tapatalk which now seems to be completely useless. I'll have to work on getting another picture hosting service I guess. I've been through 3 so far.
Sent from my SM-G965U using Tapatalk
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
Kryptoroxx is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 09:13 PM #272
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Finally got around to projectors for an upgrade. Man what a difference. Bambi is now visible. I didn't do anything fancy with these. I need to tweak the aiming a little as well and finish all the wiring up for the parking lights and turn signals. In the end I think I will be happy.
Trying to see if there is a way to wire in a drl circuit on a 98 that I can control. I know the stalks from the later models won't work with the steering column but any ideas are always appreciated.
Old 05-25-2019, 10:38 PM #273
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
How has your 2nd gen tire carrier held up over the years?
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 11:43 PM #274
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Still as sturdy as ever. I am hoping to get a redesign in with improvements as the heim joints are going to need to be replaced at some point. The Michigan winters have not been kind. It's only rust to the joints themselves and doesn't effect the tire carrier at all but the redesign would look more polished and I could probably keep the curves closer to the body.
I did remove it two years ago just to check everything and so far so good. No body damage, rust, or weakening of the mount point was detected.
Old 10-07-2019, 09:40 PM #275
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
A changing of the guard has taken place. My 3rd gen will be going on to do bigger and better things with someone else. However I will still float around and will have a new build thread sometime soon.
Old 10-08-2019, 06:20 AM #276
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
What shrouds are those? Did you get it from the retrofit source?
Sent from my Pixel 2 XL using Tapatalk
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 10:39 AM #277
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Yep. I can't remember the name off the top of my head but here's a better photo of the headlights. I didn't like the chrome so I busted that off and painted matte black.
Old 11-17-2019, 05:15 PM #278
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
So I had forgotten that I had this issue during the summer but my washer fluid has been freezing because its exposed to the elements even with deicer.
$30 bucks at Home Depot.
2' of 3" pipe
2' of 2" pipe
3" cap
3" elbow
3 to 2" adapter.
If you can find a eccentric adapter you can tuck it a little further from the ac compressor but it's not dangerously close.
I lucked out with the stock adapter fitting in there. I had to slightly modify the rubber seal but trimming it was pretty easy.
Behold the new one
Old 11-17-2019, 06:56 PM #279
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
That's a cool idea!
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 01:45 AM #280
CDXLIV444 CDXLIV444 is offline
CDXLIV444 is on a distinguished road
That's pretty sweet lol
Sent from my SM-G960W using Tapatalk
CDXLIV444 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 09:11 PM #281
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Did you end up keeping it?
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 11-30-2019, 08:37 PM #282
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
The end.
A very good friend of mine bought it off me. We helped repair and modify each others rigs for a few years when we were neighbors.
I will say that I will never ever tow a vehicle on a trailer through the Chicago area again in my life lol. What a nightmare
2014 4runner expedition build on 34's eizenjin91 5th gen T4Rs 40 09-26-2017 02:51 PM
jc's progressive expedition build Jc12 3rd gen T4Rs 12 12-08-2014 12:49 PM
Brian's Build Journal - All Purpose, Overland/Expedition 4Runner TheFriZ 3rd gen T4Rs 58 10-10-2014 08:59 AM
2014 T4R Expedition Build Mikefj40 New Members 11 03-11-2014 02:43 PM
"Light" expedition trailer build... topdown4runner Off-Roading 39 02-08-2011 06:57 PM
