Old 11-27-2014, 09:48 PM #1
achha64's Avatar
achha64 achha64 is offline
achha64 is on a distinguished road
achha64's Avatar
Brake Pedal goes to the Floor
Hi,
After 2 week ends of wheeling. Mudding, water crossing.
My brake seems to loose it's performance.
The ABS lights come when I wash the car and goes off after some 2 or 3 starts.
I need to hit the pedal almost to the floor to brake it.
I planned to bring her to the my Denso dealer and get the brake systems flush, and replace with a new fluid and check all the systems including ABS.
What cam be the main problem? Master cylinder?
The brake works fine before the off-road trip
Thank you
achha64 is offline   Reply With QuoteReply With Quote
Old 11-27-2014, 10:34 PM #2
tyr0981's Avatar
tyr0981 tyr0981 is offline
tyr0981 is on a distinguished road
tyr0981's Avatar
my guess is a brake line is stretching ALLOT, maybe it got caught on something while off road.... either water water / air / stretched line (s) are the most likely causes here, needs to be taken care of before driving on the streets obviously, good luck! please report back what you find
Ill4runner Build
tyr0981 is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 10:19 AM #3
KANO's Avatar
KANO KANO is offline
KANO is on a distinguished road
KANO's Avatar
Also check your brake master cylinder. Often times when the pedal goes to the floor, you either have air in the line or the master cylinder is bad. You can also check to see if there are any codes that you can pull. Even though you do not have a Check Engine Light, you may still have codes that could tell you where the issue lies.
And like the previous post talks about, take a look underneath and check your lines. its possible you punctured/tore a line as well. And I would strongly suggest to keep it off the road.
KANO is offline   Reply With QuoteReply With Quote
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Brake pedal goes all the way to floor, etc. ThePizzaGuy 3rd gen T4Rs 7 01-18-2013 09:31 PM
Brake pedal to the floor update Lou Maintenance/Detailing 7 01-05-2007 08:09 PM
does your brake pedal go to the floor? gonzo 4th Gen T4Rs 34 08-03-2006 01:26 PM
2001 T4R - brake pedal to the floor cracker Problems & Warranty Issues 0 10-10-2004 03:55 PM
