Old 11-30-2014, 01:28 PM #1
jeff_connors jeff_connors is offline
jeff_connors is on a distinguished road
Transmission Slipping
My 2000 4Runner, SR5, transmission slips in overdrive. A year ago, it had the pink milkshake and I caught it before it slipped. I pumped the torque converter, installed an external cooler, dropped the pan, and cleaned the magnets, and put new fluid in. In the last few months, I have noticed the slipping when on the highway under load only. Anyone else have this happen to them? Ideas?
Thanks.
jeff_connors is offline   Reply With QuoteReply With Quote
Old 11-30-2014, 06:09 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Well given the history, I'd change the fluid asap, complete flush again. All depends on how much if any coolant got into internal trans components, some parts can't handle water, they swell up and can no longer do their job, hence the slipping. Flushing again helps get the moisture out. Many on here have success with what you've done, don't know if it w/b long term or just a delay of a rebuild. Best of luck!
Old 11-30-2014, 06:37 PM #3
soundmanlpte soundmanlpte is offline
soundmanlpte is on a distinguished road
Yeah. Flush the tranny. I'd put a good synthetic in like Amsoil ATF and see if the problem gets any better.
soundmanlpte is offline   Reply With QuoteReply With Quote
Old 11-30-2014, 07:36 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Clutch packs and antifreeze go together worse than oil and water. If you have not been saving your pennies for a used one (cheaper) or rebuild, start today. Short of doing such the problem will only worsen with time.
Or swap in a 5 spd R150f instead.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 11-30-2014, 09:33 PM #5
So you believe another flush will not work?
Sorry, what is a R150f?
Old 11-30-2014, 10:41 PM #6
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Originally Posted by jeff_connors View Post
what is a R150f?
It's the manual transmission that came in 3rd gens.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 11-30-2014, 11:49 PM #7
It couldn't hurt, in fact if it gets bad enough you may try something such as Lucas transmission additive.
But the hard truth is that the coolant attacks the friction discs quickly (part of the clutch pack) and there is no real way to repair them. The transmission must be removed and torn down.
Automatic Transmissions: What Makes Them Work
If it were me I'd keep an eye out for a used tranny with low miles before having one rebuilt.
Old 12-01-2014, 04:28 AM #8
Jon's Avatar
Jon Jon is offline
Jon is on a distinguished road
Jon Jon is offline
Jon's Avatar
No way around it man.... those clutches are done!
The Milkshake
Sweet strawberry milkshake, FML....
The R150 Swap in Detail
5spd swap, HERE GOES NUTHIN!
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
Jon is offline   Reply With QuoteReply With Quote
Old 12-01-2014, 09:46 PM #9
I would not mind a manual but would that not be a lot more work by replacing the shifter and reworking the foot pedals?
Would a R150f be cheaper than an automatic?
Old 12-01-2014, 09:55 PM #10
When my torque converter bites the dust (slowly going) I hope to switch out my auto to a R150. I have priced it out, doing the work myself, to about $750 in all. It could be lower. Hopefully Jon will chime in again, and be able to provide a better total cost idea.
The cheapest solution IMHO is to find another used auto tranny. Is it 4wd?
Old 12-01-2014, 10:01 PM #11
Yes it is.
Old 12-01-2014, 10:20 PM #12
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Thanks.
Is it happening in all gears, or just one in particular? I was having an issue after my pink milkshake. I ended up replacing my 2nd and 3rd shift solenoids. After replacing those everything was good. It wasn't as perfect as it was, but an improvement none the less. Everybody has an opinion on this, and each situation is different. There are people on here that have 10k plus miles after this with no issues. There are also people who require a new transmission. Try new fluid for starters since it's your cheapest thing to try.
MStudt is offline   Reply With QuoteReply With Quote
Old 12-01-2014, 10:20 PM #13
MasonT4R's Avatar
MasonT4R MasonT4R is offline
MasonT4R is on a distinguished road
MasonT4R's Avatar
To slightly hijack...
I also have a slipping auto transmission that needs replaced. Is there any difference in the auto transmissions between the different years? I'm pretty sure they are all the A340E but I wanted to make sure there wasn't anything funny between years.
Not that I think I have much to worry about. I'm looking at a used 2000 transmission. Think I'm pretty safe.
1999 4Runner Limited 4WD Locker
2006 Lexus GX470
2013 Toyota Tundra TSS 4WD
MasonT4R is offline   Reply With QuoteReply With Quote
Old 12-01-2014, 10:41 PM #14
Just the overdrive, that may be fourth(?), when under a load such as going uphill. I'm either selling this (retiring and going back to cars) or giving it to my son but either way, it needs to be fixed. I'll try new fluid first. Thanks.
Old 12-28-2014, 10:13 PM #15
Well I tried the new fluid and Lucas. In 4th, it's slipping more and more. I think it's shot. I'd like to put in the manual transmission if that is cheaper. Can you guys give me some recommendations please?
Transmission slipping in OD??? run4estrunner 4th Gen T4Rs 8 01-01-2013 09:14 PM
Transmission slipping Soxnation13 Problems & Warranty Issues 1 09-03-2012 12:28 AM
Transmission slipping :( tofu 3rd gen T4Rs 19 01-08-2012 12:17 AM
when is transmission slipping not really slipping craigatkins Problems & Warranty Issues 2 07-30-2007 01:40 PM
slipping transmission himark Problems & Warranty Issues 2 07-10-2004 06:54 PM
