Originally Posted by 4runner6
to be completly honest im not sure all i know is that the mechanic replaced the coils for cylinder 6 and it fixed the problem for a year but now when the car is cold it runs like crap and the check engine light will pop on and the srv trac lights will come on if i drive the car without it completly heated up but once its fully heated up it will run fine except for the occasional misfire around 50mph but its not nearly as bad as before the coils where replaced im just worried that this is going to be the start of it getting bad again the car has 180,600 miles on it
If you had a mechanic do it most likely he used non OEM parts. These things dont like non oem electronics. Coils, alternators, starters usually fail 1-12 months after install. I would suggest having the coils tested, see if one if failing again. If so get some used oem coils if possible or buy oem new coils online and have them installed.
