12-02-2014, 02:50 AM
Odometer is fading away...
Can't seem to find any answers about this. The decimal of the odometer is starting to fade and it makes it difficult to know what number it is displaying. It's not a big deal, but it annoys me, especially come time to fill up.
Does anybody know if I can take an odo out of another instrument cluster and replace mine while still showing the original mileage? Does the info get stored somewhere else or is it tied into that specific odo display?
Thanks!
The Renewal of Gaia 1999 4Runner SR5 Highlander IJM
FJ Wheels | Goodyear Wrangler Fortitude HT | TBU
Rancho Shocks & Struts | OME 880 Front | OME 906 Rear | ES Polyurethane Sway Bar Bushings Front/Rear | ES Polyurethane Steering Rack Bushings
Clear Headlight Corners | '98 Rear License Plate Frame & Emblem Delete | Stubby Antenna | Trans Cooler Bypass
12-02-2014, 03:01 AM
Digital right? Then get a new bulb. Or go old school and tap it till it works.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
12-02-2014, 10:43 PM
My digital odometer is the same way. You can barely read the milage at night, forget about daylight. I have a friend at the dealer I'm gonna ask. I'll let you know if he recommends changing the bulbs.
12-03-2014, 12:33 AM
I'd say remove the instrument cluster and pull all the light bulbs. Clean the light bulb with a damp cloth.
Can you see the other indicators well?
12-03-2014, 06:34 PM
I didn't realize the odometer was just a bulb. All the other bulbs in the cluster work just fine, including the other digits of the odometer. dphflytyer, thanks! Let me know what he says.
Here's a pic of what I'm talking about. You can see the decimal should be showing 0 right now, but only the left side is fully illuminated, the top, bottom, and middle (and sometimes the middle e.g. an 8) is faded:
12-03-2014, 07:04 PM
That doesn't seem to be build related. Man, keep us updated...mine will most likely do the same, she is getting a bit long in the tooth.
1999 4Runner SR5, with some stuff...
OverlandNV
You can also follow us:
Facebook OverlandNV
Twitter OverlandNV
12-03-2014, 07:06 PM
Sorry, the bulb won't help you in this. Picture is always nice to assess the situation. Have you tried to re-solder all the connecting points int the LCD display going into the circuit?
I am glad I have old school style!
12-03-2014, 09:50 PM
LOL I guess it's staying dim for a long while! So there's no way to swap a JY odometer in place?
11-08-2017, 08:17 PM
So this started happening to my truck within the last week. Have you found a fix for this or do I need to start doing some testing?
2000 millennium silver limited, TRD 1st gen supercharger, Toytec/eibach 3"springs, Tundra 5100's,LC 8 wraps w/ bilstein 5125's, 285/70/17 toyo mt's on FN FX Pro in matte bronze
2015 Harley FXDB 103, cams, thrashin supply pipe, vance and hines tuner, LED lights all around
1st gen, 4 inch lift, 35/12.50/15 goodyear MT/R, GONE
My build http://www.toyota-4runner.org/3rd-ge...ml#post2828875
11-09-2017, 03:41 PM
Fixed it. One of the plugs was half unplugged
11-09-2017, 05:33 PM
Great, was it one of the plugs behind the instrument panel?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
11-09-2017, 06:20 PM
No it was a circuit board plug in behind where you swap the bulbs for your gauges
11-09-2017, 06:38 PM
We have a saying at work: 90% of electrical problems are mechanical.
Of course, I design electronics for a living.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-09-2017, 07:09 PM
Real Name: C8H18 Mike
But doze ribbon connectors doe
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
11-10-2017, 12:28 AM
Works real good now
