Originally Posted by 2TH4IST
@ midcoma
@ sleepydad
thanks guys for the pics! Keep me updated on those brackets. Sleepydad do you know how much waterjetting cost for a set?
well you see here is the problem with getting thing done. if you want the brackets to cost maybe like $20 each then you will need to have 100 sets of them done. once they setup and run a sheet of the steel it's pretty economical.
however just to run one set of brackets is going to run you $200 at least I would think. unless your friend runs the water jet cutter and can do it on the side for you @ cost or for beer or something like that?
your best bet if you want just one set is to print out the file in sketchup or any other tool that will let you as a parallel projection with no scale so it's 1:1 real life size.
as an example I needed a bracket for the ebrake part of the disc brake setup
PAD tempate (paper aided design)
cut out on the small fry saw
and cleaned up on the scary sander
edit: and I was feeling ok until I just read the news... god dam we are all so focked.
