Originally Posted by DPR64
So the raw height with 99 tall and the Tacoma 5100 struts on the MIDDLE setting is 2" combined with the tall coil or 2" PLUS the extra 1" the tall 99's give someone?
I am in a 2000 so I need to find out if the that combo will end up being either 2" or 3" overall from my old standard coil setup...
Middle setting put me at 1.75" to 2" from the stock height of my 98 with stock coils. So if you had the same setup as me you would probably be between 2" and 2.25" from your stock 2000 height. That additional height would come from the fact that the 98 sat .25" or so higher than a 2000 stock. So you should net a little more lift than I did
Edit: My educated guess for the three settings for you (if you use 99 coils and Tacoma 5100s) would be this . . .
Bottom setting = 1-1.25" lift
Middle setting = 2-2.25" lift
Top setting = 3-3.25" lift
Again this is considering you have a 2000 with stock suspension.
