Originally Posted by fourwd1
A relay will not cause a short, if it is not working properly it just won't complete a circuit and turn something on.
Now if there is a short downstream from the relay, when it is energized and completes the circuit the fuse would blow.
You can never say never, oh wait, I just did.
OK, so be careful, Relays CAN cause a short, its just that in 30 some years of electrical troubleshooting, I've maybe seen it twice. And the first one was questionable.
In this particular circuit if the relay was the culprit, it would be blowing the 120A main fuse, because it is powered on both sides by that fuse. It is activated by grounding the switch, which is why you hear it clicking. Once activated it sends power to the 10A tail lamp fuse then it is distributed from there.
The logical and easiest thing to do is disconnect connector 1E at the Driver's side FuseBlock, or Body ECU. This will take out the entire tail lamp circuits on both sides of the vehicle including the rear gate. It leaves the front marker lights and the instrument panel lighting intact.
The next step is to disconnect connector 1B at the same location. This takes the instrument panel out of the loop.
Do this and report back the results. I can solve this in 4 fuses or less!
