12-31-2014, 05:18 PM
Real Name: Mason
Real Name: Mason
Whiteline W53377A lower control arm bushings
Anyone using these? I need new lower control arm bushings. These are $62 for all four. Dealer wants $42 for each bushing which is a heavy price to pay! Whiteline states the W53377A are inner bushings. What is the meaning of this?
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
12-31-2014, 07:19 PM
Real Name: Nate
Real Name: Nate
I have no idea.
A guess? Maybe this aftermarket kit only includes the metal sleeve of the bushing, not the outer, plastic/rubber portion--just a wild guess.
Have you looked at TRDpart's site yet?
long travel F/R, major fabrication work, shrockworks armor, whitsonmetalworks, dual-rate coilovers F/R, warn, rigid, ARB, more buttons than brains.
12-31-2014, 08:12 PM
Real Name: Andrew
Real Name: Andrew
The kit includes everything you need to replace. Bushings, sleeves and cups. Much better than OEM.
97 FZJ80 40th Anniversary Edition wife-mobile/weekend wheeler
SOLD'98 T4R 5spd, e-locker, Boss coilovers, LC 8wraps, Tokico blacks, SS extended bump stops, 255/85r16 Toyo M/T's
http://www.toyota-4runner.org/3rd-ge...ml#post1707857
12-31-2014, 11:49 PM
Real Name: Mason
Real Name: Mason
Thanks for the info. Do you run them or anything else from the line?
01-01-2015, 01:39 AM
I have them. I like them. I think I've put about 10k miles on them. The kit comes with everything you need.
01-01-2015, 08:12 PM
Real Name: Andrew
Real Name: Andrew
I do run them, and like them. Don't have anything else from whiteline though. Used energy bushings on the steering rack installed at the same time.
01-01-2015, 08:17 PM
Real Name: Mason
Real Name: Mason
Thanks for the info. Just bought them on amazon
Just noticed I purchased w553377 which was discontinued and replaced with w553377a. Any differance in the older model?
http://www.amazon.com/Whiteline-fron.../dp/B0070I8M78
01-02-2015, 12:03 AM
Real Name: Isaac
Real Name: Isaac
its what i put in my 4runner. they are great, didnt have any issues with them. way easier to install the stock bushings.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
01-02-2015, 12:58 AM
Real Name: Mason
Real Name: Mason
Originally Posted by ChildrenOfBodom
i'm going to order some of these too, just sucks about the wait time
I called the company and they do have a lead time of 4-8 weeks on the W53377A. Looks like both amazon and ebay have the W53377 in stock which is the older model. Does anyone know what the difference is?
01-04-2015, 02:43 PM
Real Name: Andrew
Real Name: Andrew
Should have asked why you had them on the phone I guess. I ordered mine from Amazon and probably got the old part number, they worked perfectly so I'm not sure what advantage the new number could have.
12-21-2015, 11:58 PM
Bringing this thread up b/c I'm getting ready to install my whiteline front lower control arm bushings.
For anyone that's installed these, did you grease the outer most metal sleeve that surrounds the polyurethane bushing before installing it into the LCA? (the metal outer bushing sleeve that contacts the LCA)
I've asked a couple people & some said "yes" to grease the outer metal bushing sleeve in order to allow the entire bushing to rotate within the LCA and some said "no" b/c the outer metal sleeve is supposed to fit snug into the LCA & should not rotate, only the polyurethane bushing itself should be greased so it can rotate. I spoke to one of the guys from whiteline and they recommended to put a light coating of grease on the metal sleeve.
I'm kinda leaning towards not greasing the outer metal sleeve based on the what I was told & it seems that the OEM bushings does not have grease on the outer metal bushing sleeve. Thoughts?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
12-22-2015, 12:28 AM
Real Name: Isaac
Real Name: Isaac
Do not put grease between the bushing and the control arm... That needs to be a snug fit. For me I stuck my assembled bushings in the freezer for a few hours and the control arms in the oven and then install them without the need for a press.
12-22-2015, 11:04 AM
What part number did you end up ordering?
The one that ends in an "a" ???
Where did you order it from and how long did it take to ship?
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
12-22-2015, 12:19 PM
Part number is W53377A and ordered through the whiteline site and took about a week to come in. But when you place the order it will say aftermarket suspensionparts.com ....looks like es, prothane, & whiteline are all under aftermarketsuspensionparts.com bc when you go to each site, they all list the same contact number.
However i was given a direct number to whiteline regarding some specific questions about the bushings before i placed my order.
