01-06-2015, 12:26 AM
Brake Warning Light
For the past few months, the Brake Warning Light would turn on and off as I am driving. It usually turns on during acceleration, and will turn back off while cruising.
I have made sure the hand brake was not engaged and I am not aware of any other places it would work. Any ideas?
01-06-2015, 12:30 AM
Location: Stationed in Camp LeJeune, home is Conover, NC
Low fluid.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
01-06-2015, 09:24 AM
Moderator
Real Name: The Chosen One
Moderator
Brake fluid, in the master cylinder, to be specific.
'89 4Runner SR5 - stock
01-06-2015, 12:31 PM
Originally Posted by Doc2012
Low fluid.
agreed.
usually this means you need front brakes. as the brakes wear, the pistons extend, increasing the volume of fluid pulled from the res.
or a leak. but based on your description, I don't think its a leak.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
01-07-2015, 02:47 AM
Originally Posted by nevada
agreed.
Yea that 👆
97 4runner 3rzfe 5speed
D44 sky mfg sas
Dual transfer cases
toyo 37s 5.29 locked F&R
York OBA compressor
11-18-2018, 09:37 PM
Brake warning light and faulty cruise control
I'm having issues with the brake warning light coming on, which I think might be related to issues with the cruise control--as it is faulty and often doesn't work or it disengages when it does work.
I have checked check brake fluid level in the reservoir and it's at "Max", and i changed the front brakes (pads, rotars, and caliper on one side) roughly two months ago. The vehicle doesn't pull to the left or right when I brake, so I know it isn't a cylinder problem... But still a problem.
Thoughts?
1991 Toyota 4runner sr5
V6 4x4
11-18-2018, 10:17 PM
Based on your vehicle description it looks like you posted in the wrong section. Although just a thought check brake switches. Cruise control disengages if the brake is hit so maybe a bad switch could cause your issues. Although brake light only comes on if the parking brake is engaged and I’m not sure if that can disable cruise control.
97 4Runner SR5 4x4 manual trans.
2.5” lift, OME 881/890, Bilstien 5100(4Runner specific)
Tundra brake upgrade (231mm)
11-19-2018, 12:17 PM
Thoughts?
V6 4x4
maybe the float sank. you could slide the float up and see if the light goes off. or unplug the pigtail at the cap. double check the button on the park brake. make sure its being full pressed in.
but yes, if the brake warning light on, that will deactivate cruise control.
11-19-2018, 03:51 PM
Real Name: Jerod
Real Name: Jerod
Thoughts?
V6 4x4
Also make sure the parking brake is completely dis-engaged. Sometimes that little switch telling it the handle is all the way down gets dirty and doesn't ground like it should. You can pull the center console to check if it comes to that.
