Old 01-07-2015, 01:21 PM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
Front diff drop needed for 3" OME lift kit?
I was on toyteclifts.com and was checking out the OME suspension lift kit. There's an option for front diff drop and the options were "Yes - Add to kit" and "No (2wd)". I have a 97 4wd limited. Do I need to get the front diff drop for this? Planning on getting the 881 front coils with top plate spacers to get 3" lift.
benjamin247 is offline   Reply With QuoteReply With Quote
Old 01-07-2015, 02:05 PM #2
AZTOY's Avatar
AZTOY AZTOY is offline
AZTOY is on a distinguished road
AZTOY's Avatar
I have Toytec coliovers cranked up to 3" and do not have a diff drop. Off road regularly with a lot of articulation on rocks and DD. No problems. Personally, I chose not to do this. Based on my research and experience, I do not think it is necessary. You will get strong opinions on both sides.
Have you read this:
3rd Gen 4Runner Lift Information and FAQ's
97 V6 4X4 AT; ICON 2.5 EXT TRAVEL COILOVERS / SS 1.2 REAR; AUSSIE LOCKER; TC UCAs; SAVAGE OFFROAD SLIDERS AND SKID PLATES; ARB BUMPER; WARN WINCH; LOTUS CONTROL ARM SKIDS; DECKPLATE/ISR; 265/75/16 BFG KM2
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
AZTOY is offline   Reply With QuoteReply With Quote
Old 01-07-2015, 02:27 PM #3
deverlow's Avatar
deverlow deverlow is offline
Real Name: Andrew
deverlow is on a distinguished road
deverlow's Avatar
Real Name: Andrew
I personally have the Toytec diff drop and only mildly wheel, although wheeling in central Texas is a lot of rock and a lot of articulation. I have torn two boots in two years and would rather be safe than sorry.
I'm not overly vocal either way and ultimately it's up to you. For as cheap as they are and as easy to install as they are, I'd rather have the peace of mind.
1997 T4R 5VZ-FE 5 speed | Rear: OME 891s + stock FJC shocks | Front: OME 881s + 90004s | Toytec diff drop | 265/75/16 BFG ATs | Front sway bar delete | Rear diff extended breather
deverlow is offline   Reply With QuoteReply With Quote
Old 01-07-2015, 02:34 PM #4
9494runner's Avatar
9494runner 9494runner is offline
Real Name: Rhett
9494runner is on a distinguished road
9494runner's Avatar
Real Name: Rhett
you can lift it with out a diff drop, but when you look at your CV angle you will be like oh, I do NEED a diff drop. angles get severe pretty fast. I would say yes you will need/want a diff drop if you want to keep your CVs happy and not binding. also your labor in the long run will be cut down as you wont have to reboot all of the time depending on if you have manual hubs or use your 4x4 alot. Boots rip pretty easy, maybe alittle too imo
Vinette: 1994 4Runner Black SR5, 3VZE (ARP Headstuds, MLS gaskets, and Flamethrower Injectors) Auto,31/10.5/15 Cooper AT/3s, Aisin Hubs, AOR Plate Bumper, 1.5" Lift: Rancho RS5000s, 4Crawler diff/sway/Pan-Hard Drop, BJ-Spacers, OME Rear Springs, SS TG brake lines, Cobra CB.
9494runner is offline   Reply With QuoteReply With Quote
Old 01-07-2015, 02:38 PM #5
Taylor20's Avatar
Taylor20 Taylor20 is offline
Taylor20 will become famous soon enough Taylor20 will become famous soon enough
Taylor20's Avatar
Please search as this topic has been covered 1,385 times
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
Taylor20 is offline   Reply With QuoteReply With Quote
Old 01-07-2015, 02:52 PM #6
9494runner's Avatar
Real Name: Rhett
9494runner's Avatar
Real Name: Rhett
It definitely has been covered; he could and should use the search function. but for the same time it took to post that, you could have nicely provided the very simple answer to his question and help a member out!
Old 01-07-2015, 03:12 PM #7
d0nkeyxpunch's Avatar
d0nkeyxpunch d0nkeyxpunch is offline
d0nkeyxpunch is on a distinguished road
No need for diff drop, but for $30-40, I guess you can just get it. Super easy to install too.
d0nkeyxpunch is offline   Reply With QuoteReply With Quote
Old 01-07-2015, 07:01 PM #8
Have you read this:
Thanks all for the helpful info and links. Since it is fairly inexpensive, I'll play it safe and install a diff drop if I do go the OME lift kit.
Found another lift thread where front coils from a Tundra TRD was used with Bilstein adjustable shocks giving just a 2" lift and has a smooth ride. From the link AZTOY sent, it says if it's 2" or less I won't need a diff drop. Maybe I'll go with that one. Arrgh...decisions, decisions. Thanks again for all your input!
Old 03-09-2016, 02:05 PM #9
Mtbkr's Avatar
Mtbkr Mtbkr is offline
Mtbkr is on a distinguished road
Mtbkr's Avatar
Gen 5 Differential Drop After 3" OME Lift
I foolishly purchased and installed a differential drop for my 3" OME lift in my 2016 Toyota 4Runner Trail Edition. It really bugged me that spacers are required for the front and center skid pans. The front skid pan is removed to access the oil filter. Imagine having to deal with that or convey the existence of those spacers to the shop doing the oil change.
So ... I took a pictures with the diff drop installed and with the diff drop removed to show that there is almost no difference in CV shaft angle.
A diff drop in a Gen 5 is not required for a 3" lift.
With the drop installed
Without the drop installed.
Based on these results the diff drop is in the spare nuts and bolts drawer.
BTW ... the strut is labelled passenger but is installed on the driver side. Can you guess why?
Mtbkr is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 02:13 PM #10
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
OK....? Did you get lost on the way to the 5th gen section?
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 03:17 PM #11
Jhelms's Avatar
Jhelms Jhelms is offline
Real Name: Jeremy
Jhelms will become famous soon enough
Jhelms's Avatar
Real Name: Jeremy
There is a clear angle difference between your with / without photos. Every degree counts when it comes to longevity of your CV axles and boots. Are they a MUST have? Not really but I still would recommend them if you plan to keep your ride for a LONG time.
I installed cheap Revtek spacers / RTDD1-KB. Hopefully they worked out the issues with their kits. Think they ran about $30ea. As the diff is lowered to insert a spacer, you can literally watch the CV angle change. It is drastic? Nope. But again, every single degree helps.
Only thing that has to be done on the 3rd gen is to elongate the skid plate holes. Installation is quick and easy.
Install pics can be found starting on post 85 if anyone cares.
My 4gunner restore, refurb and re-work
01 LIMITED 4WD 250K | 02 SR5 4WD 230K | ALWAYS WRENCHING THREAD
MY_4GUNNER_RESTORE_REFURB_REWORK_THREAD
FAVORITE_TOOLS/TECH_TOOLS THREAD
Jhelms is offline   Reply With QuoteReply With Quote
Old 03-10-2016, 07:00 PM #12
Mtbkr's Avatar
Mtbkr's Avatar
I did. But I really question the need for the diff drop. I'm sure it depends on the generation of 4Runner (or Tacoma for that matter). The shorter the CV shaft, the greater the angle change for each inch of lift. I lifted a '95 Tacoma and it was obvious the diff drop was needed. But a couple of degrees of change in CV angle I don't think will make or break. I shall see.
Old 03-10-2016, 07:15 PM #13
Mtbkr's Avatar
Mtbkr's Avatar
Would you be so kind as to post a picture of you rig's driver side CV shaft similar to the perspective as mine? I am very curious. That is a great idea of elongating the skid pan holes.
FS: 3" OME lift with diff drop! 3rdPedal97 For Sale: Suspension/Wheels/Tires 12 12-01-2012 10:10 PM
FS 3Rd Gen 1" BL and/or Front Diff Drop kit corny For Sale: Suspension/Wheels/Tires 13 01-30-2012 11:37 AM
FS 3rd Gen 1" BL and/or Front Diff Drop kit corny For Sale: T4R Items 1 12-12-2011 10:33 PM
F/S 3" revtek spacer lift w/diff drop toytech76 Classifieds - buy & sell (no commercial ads please) 0 05-29-2009 01:41 AM
Lift Kits and Front Diff Drop XJeepguy 3rd gen T4Rs 4 05-09-2008 12:28 PM
