snivilous
I see you have been around the Bountiful B and I have driven every road on that mountain, even places where there are not trails.
IMO I wheel hard enough to get sufficient articulation that would cause rub. I have encountered situations in which I have to turn the wheel to fully locked and it had very minor rub on the UCA.
I just don't see why you have to deny what is being done, you can rant all you want about how 33" tires won't work. I put on my 33's with the intention to lift and I have.
If you get a real lift system the the tire will still articulate to the exact same position as the stock suspension (assuming you do not have new bump stops). The point I am trying to make by saying this is that the lift is not going to solve rubbing issues off road. A body lift would fix that problem, but a suspension lift should not. That is why I believed that running 33's stock was doable. I ran it for 3 months with ease, including off roading every weekend.
You can say all you want. I did it. It worked for me. Might not have been perfect, but it worked. End of story.
