04-20-2017, 10:59 AM
#61
Originally Posted by MattJakobs
How do you guys like the latch mechanism? Secure? Locking? Have any detailed pictures?
@ Unner
@Chim
Latch is super quick, simple and solid! Its easy to use even when opening for groceries. I don't have detailed pics but in my old pics you can see the bar that the latch connects to. Then the next pic shows the handle and lock pin. It basically wraps over the bar and the spring pin keeps it in the locked upright position.
04-20-2017, 12:03 PM
#62
The latch talk reminded me. If I were going to order one again (which obviously, I'm not) I think I'd get the tire carrier reversed, swing on the driver side, latch on the passenger side. Two reasons:
- The tire would be moved over to the driver's side as well. This would get is slightly more out of the sightlines of the driver. Not so much when looking out the rear view mirror, but when looking backward while reversing, your sightline tends to be more out that side.
- It would be more compatible with a swing-out hitch mount bike carrier. Every single one I've found swings to the passenger side, and when combined with the swingout tire carrier you end up with a conflict. We bought one and had it modified (extended the swingout arms, plus extended the vertical beam for more off roading clearance with bikes mounted), but with them going opposite directions it would be better.
04-20-2017, 01:16 PM
#63
@ Unner
@Chim
Latch is very secure. If the pictures Chim posted aren't clear on how it works I can get some more. It does require two hands, but that makes it all the more secure. It's not like I frequently open the hatch for normal driving purposes. If I have something with me most likely it's just going in the backseat unless I've got a bunch of stuff or passengers.
The main reason most of the swingouts swing in that direction would be to keep you out of way of the flow of traffic in the event you have to open the swingout, change the tire, or whatever on the side of the road. Assuming you pull to the right of the road like you would in 95% of situations. I'm sure they could build it reverse though if you asked.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
04-20-2017, 01:45 PM
#64
Originally Posted by Road Bull
Yeah... I don't really sleep. I should try to get to bed at a respectable hour, but, I love burning candles on both ends. LOL.
And what can I say, we have good taste! I try to research the hell out of things I add to my rig. And this is a big one.
I am wondering just what this would do to my LC 7 wraps. I currently love the way my 4runner sits and rides, but that is a hefty weight increase. 861s seem like the go-to springs, but I wonder if some use 8 or 9 wraps LC coils.
I still run my 8 wraps and they ride just fine. No more squirrely with the bumper than without. There is still a respectable amount of rake too
'96 4runner Limited - Automatic 4wd with factory E-locker - LT265/75r16 BF Goodrich KO2's - Toytech/Eibach front coils and LC 8 wraps with Bilstein 5100s all around - SPC UCAs - AOR Plate Front Bumper - 4xinnovations Rear Swingout Bumper - HD-SKO Sliders
04-20-2017, 03:01 PM
#65
I certainly understand why that's the default (like the sliding doors on vans). Just saying that anyone who wants to use a hitch mounted bike rack will find it to be a real PITA to deal with, assuming you want to have the rack, and the swingout, and still be able to open the rear hatch with only a modest amount of hassle.
We have a different bike rack that folds down, but the vertical portion is still too tall to allow the swingout to open when it's folded down.
The sightlines issue is modest, but something that happens a lot more than stopping on a busy road and opening the rear hatch. When you turn around and look over your right shoulder out the rear window, you're looking mostly at the tire on the passenger sid.
FWIW, in Japan where 4Runners (Hilux Surfs) have factory mounted rear spares, they're on the driver's side, not the passenger side.
Just some food for thought, I'm very happy with my bumper, it's just that if I'd thought of this before we had them built, I'd be even happier.
04-20-2017, 03:10 PM
#66
Real Name: Evan
Real Name: Evan
Probably because they drive and park on the left side of the road, opposite of us? Makes sense!
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
04-20-2017, 03:40 PM
#67
Real Name: Ryder
Real Name: Ryder
Care to post some pics?
04-20-2017, 03:58 PM
#68
And the driver's side is on the opposite of the car. So the factory spare tire swingout is on the same side (right) as this is, even though we drive on the opposite side.
Driver's side was certainly a confusing term to use in my post, I'll admit.
/\ /\ /\ Swings to the driver's side, not the passenger's side.
04-20-2017, 04:00 PM
#69
Real Name: Matthew
Real Name: Matthew
If you wouldn't mind, please.
I don't use the back hatch all that much either but seeing as the 4Runner is my DD, I'd like it to be pretty easy for convenience sake.
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
04-20-2017, 04:22 PM
#70
Real Name: Scramble
Real Name: Scramble
@ IsaiahC
, @Chim,
@ cbr900boy
@ Unner
Thanks for posting!
It's always good to hear people that are happy with their gear and experiences getting and using it. I liked the modular aspect offered by the Savage rear bumper, but I had a chance to see Chim's bumper in person and I was impressed. It looked stout, and incorporated all the options I am interested in at a fair price.
Are most of you using 861s? To compensate for the added weight? I currently have 7 wraps LC coils. I do like the raked stance. I would also look at putting in the Sonoran Steel body mounts right off the bat to avoid body flex contact.
@ cbr900boy
did you want the 1" BL in general, or for bumper clearance buffer?
I have 8 wraps & bought them knowing that someday I'd buy a swing out bumper. Many people were happy with that set up when I was researching old threads here. It will reduce my stink bug look & I'm fine with that.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
04-20-2017, 04:27 PM
#71
I'll try and get some for you later today.
04-20-2017, 04:38 PM
#72
Real Name: Evan
Real Name: Evan
Point taken, didn't realize that they're RHD but either way the swing out would be opening into the side of passing traffic for JDM Surfs, so that's interesting that they'd design it that way from a safety aspect.
04-20-2017, 06:06 PM
#73
Real Name: Ryder
Real Name: Ryder
Man... at times I wish their was a build thread excel page that listed components for people's builds.
Ideally it would be searchable and you'd have the ability to click on, let's say 4X Innovations rear bumper and the returns could be filtered to cross check against other equipment. This way, without playing memory, you could get a list of build threads of people using a combination of equipment you are researching.
Keep the 4X Innovations rear swing out pics coming.
This thread has been a great resource.
04-20-2017, 06:14 PM
#74
Does anyone have a pic of the fold down cook tray?
04-20-2017, 06:25 PM
#75
This is a great idea. I spend a lot of time researching my parts before I buy them and this would make it a little easier.
