t4r4life
Old 01-03-2020, 02:48 PM #31
binqker's Avatar
binqker binqker is offline
Real Name: John
binqker is on a distinguished road
binqker's Avatar
Real Name: John
Originally Posted by norcalassassin View Post
Anyone interested in the wheels/tires on my truck?
How much?
John
2002 TCM Grey Sport Edition
binqker is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 02:55 PM #32
norcalassassin's Avatar
norcalassassin norcalassassin is offline
Real Name: Zac
norcalassassin will become famous soon enough
Real Name: Zac
Update 1/3/2020
Reflectix window insulation and cooler mod
Going to camp at some hot springs tonight, probably the last trip for awhile... got some chopping to do.
Camper runner-img-9952-1-jpg  Camper runner-img-9953-1-jpg
1998 SR5 5 spd 4x4 3.4L + some other stuff
1985 Tercel 4WD SR5 6spd, 4A swap
2006 Saab 9-2x Aero 5spd (saabaru)
IG: r0amerr
https://www.toyota-4runner.org/3rd-g...ce-thread.html
norcalassassin is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 02:56 PM #33
Real Name: Zac
Real Name: Zac
Originally Posted by binqker View Post
How much?
1100, entertaining all offers
IG: r0amerr
Old 04-15-2020, 10:36 PM #34
Real Name: Zac
Real Name: Zac
Update 4/15/2020
Lots of work getting done on the 4runner, hoping to have it back on the road by the end of April. I decided to go a bit more extreme with the rebuild, which will allow me to spend less time under this thing.
- New (oem) LCA's are on with eimkeith skid and limit strap kit, also replaced all of the alignment cams. (mine weren't seized but replaced for peace of mind)
- Added some weld next to each alignment tab on the frame to increase the strength of the stock tabs.
- Total chaos spindle gussets are welded up and pressed with new Koyo wheel bearings
- eimkeith strut tower re-enforcements are welded on (photo only shows tacks)
- Trailgear creeper breather (used a Toyota union for the axle housing) and custom mount for the e-brake cable "holder"
What's left to install...
- Champion radiator
- SPC UCA's
- Bilstein 5100 ext rear shocks
- Toyota front axle seals
- F/R Differential and Transmission fluid change
- Replace all drain/fill plugs and gaskets
- TIRES! 255/85/16 Yokohama Geolandars
Pretty happy that my pile (mountain) of parts is finally shrinking.
Camper Build:
- Sketch with some design revisions
- Ordered a Tern Overland window (300x500) going in place of one of the rear windows (haven't decided driver or passenger side) . Both rear windows will be removed and paneled with sheet metal.
My plan is to start on the structural build of the camper this summer after I get some trips in on the rebuild.
Camper runner-img-0242-min-jpg  Camper runner-img-0518-min-jpg  Camper runner-img-0517-min-jpg  Camper runner-f0a0e47c-ffbc-4488-a2b6-6bd55c0e5495-min-jpg  Camper runner-img-0536-min-jpg  Camper runner-img-0545-min-jpg  Camper runner-img-0558-min-jpg  Camper runner-img-0261-min-jpg
IG: r0amerr
Old 04-16-2020, 10:19 AM #35
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
I told my wife i wanted to do that with rear windows a while back and she thinks im nuts, pumped to see that and the camper!
great work on beefing up all the underside bits, i probably need to soon
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 03:38 PM #36
Real Name: Zac
Real Name: Zac
Talking
Hahaha, I feel you there. Everyone asks why I’m gonna cut holes in it... cause it’s fun!
The front end was long overdue of an overhaul, the LCA bushings disintegrated and the truck wouldn’t drive straight Hahahah.
IG: r0amerr
Old 07-01-2020, 11:10 PM #37
Real Name: Zac
Real Name: Zac
Update 6/1/2020
Camper build beginnings...
Driver side rear quarter window plate with Tern Overland window cut-out.
Hoping to have this laser cut soon. It will be cut out of 0.125 aluminum sheet.
Camper runner-screen-shot-2020-07-01-20-05-28-jpg
IG: r0amerr
Old 07-04-2020, 10:23 AM #38
Big-B1975 Big-B1975 is offline
Big-B1975 is on a distinguished road
Your runner is really coming together! How do you plan to bend your rear window panels to match the contour of the originals and would you be willing to sell another set without the cut outs?
Big-B1975 is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 03:48 PM #39
Real Name: Zac
Real Name: Zac
Thanks! The 0.125 aluminum is pretty flexible, contouring shouldn’t be an issue.
I’ll know more once I install it. Gonna use sikaflex 252 and through bolt in some places.
Yes I can definitely get you a set without the cut outs once I confirm fitment. Should be getting the panel back next week Camper runner
IG: r0amerr
Old 07-11-2020, 03:50 PM #40
Real Name: Zac
Real Name: Zac
Work stuff
IG: r0amerr
Old 07-11-2020, 03:58 PM #41
Real Name: Zac
Real Name: Zac
Norcalassassin's build thread (pop-top 4runner)
Photo dump June - July 2020
2006 Subaru Legacy GT seats installed.
They aren’t a direct swap, I used the 4runner seat brackets and welded them to the Subaru seat rails.
Comfort is amazing, I’m 6’4”.
Temporary window while waiting for CNC.
Shop trip in Lakes Basin.
Floor material for the floor in the camper area. Lonseal DR802.
Floor cut out, I used ACX plywood. Planning water tank and fridge/freezer location . 16 gallon Recpro tank.
I still need to make the rear body mount access hole accessible through the floor..
IG: r0amerr
Old 07-11-2020, 06:50 PM #42
dkerr's Avatar
dkerr dkerr is offline
Real Name: Daniel
dkerr is on a distinguished road
dkerr's Avatar
Real Name: Daniel
Super stoked to see how the camper build turns out! I'm a huge fan of pop up style camper conversion and might consider this when I have loads of free time!
__________________________________________________ ______
2000 Toyota 4Runner SR5
3in Toytec/Eibach Lift
265/75R16 General Grabber ATX's
dkerr is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 05:47 PM #43
Real Name: Zac
Real Name: Zac
Rear window panel v1 - 7/30/2020
Cutout is for a 300x500 mm Tern Overland window.
Waiting for the adhesive to cure and then I can pop in the Tern window Camper runner
IG: r0amerr
Old 07-31-2020, 01:38 PM #44
MattJakobs's Avatar
MattJakobs MattJakobs is offline
Real Name: Matthew
MattJakobs has a spectacular aura about MattJakobs has a spectacular aura about MattJakobs has a spectacular aura about
MattJakobs's Avatar
Real Name: Matthew
How do you plan on supporting the weight of the camper? Seriously looking forward to this thing
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
MattJakobs is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 01:56 PM #45
SherpaEquipmentCo's Avatar
SherpaEquipmentCo SherpaEquipmentCo is offline
official vendor
SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold
official vendor
Super excited to see how this turns out. There was a pop-top 3rd gen down the street from our shop for a while that was all custom fiberglass and canvas, it was pretty cool.
Industry Leading Modular Storage Systems that allow you to Adventure with Confidence.
Our WebsiteOur InstagramOur Facebook
SherpaEquipmentCo is offline   Reply With QuoteReply With Quote
3.4l v6 , 3rd gen , 5 speed , lifted , mods
zacattack20's Matte Blue ‘98 to '02 Sport Edition - Not the normal build thread zacattack20 3rd gen T4Rs 398 06-22-2022 12:15 PM
CodyX36's 1998 4Runner Build-Up Thread CodyX36 3rd gen T4Rs 68 04-23-2016 02:21 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
atra_m0rs build thread - 1998 T4R SR5 atra_m0rs 3rd gen T4Rs 4 03-01-2014 04:58 PM
1998 4WD SR5 Build Thread Calvin52 3rd gen T4Rs 5 12-10-2013 11:42 PM
