Old 01-17-2015, 10:23 PM #1
CZ Eddie CZ Eddie is offline
CZ Eddie is on a distinguished road
Exclamation Front seat bolt thread ripped out of floorboard
Ugh, I was tightening the front left bolt that holds down my drivers seat when the darn thing just popped right out of the freaking floorboard. So now there is a small hole where the bolt-hole thread used to be.
Any inexpensive suggestions?
CZ Eddie is offline   Reply With QuoteReply With Quote
Old 01-17-2015, 10:33 PM #2
SilverRidgeRunner1's Avatar
SilverRidgeRunner1 SilverRidgeRunner1 is offline
Real Name: Justin
SilverRidgeRunner1 is on a distinguished road
Real Name: Justin
Get a couple of washer and a long stainless steel bolt and nut and run it through the hole and tighten up .... Question was this due to floor panel rust.
SilverRidgeRunner1 is offline   Reply With QuoteReply With Quote
Old 01-17-2015, 10:35 PM #3
Kinnick's Avatar
Kinnick Kinnick is offline
Kinnick is on a distinguished road
Kinnick's Avatar
This just happened to me. If you search you will find the front left to be a common problem as these vehicles age. I just drilled a hole through the existing hole down through the floor. I then bought a new longer grade 8 bolt, some fender washers and a nut. I applied some silicone on the washer to create a nice water tight seal from the underside. It is probably now stronger than the original design. Easy and inexpesive.
Kinnick is offline   Reply With QuoteReply With Quote
Old 01-17-2015, 10:35 PM #4
That's not a bad idea, thanks.
No, there was no rust that I saw.
I had been using this spot for my heavy gauge car stereo grounding spot. So it had been getting removed/tightened several times over and I probably put a lot of stress on the joint.
Old 05-15-2016, 06:13 PM #5
calisurf calisurf is offline
Real Name: Nate
calisurf is on a distinguished road
Real Name: Nate
How do I access the area under where I need to put a nut and washer? I can't seem to find any ways in.
calisurf is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 06:45 PM #6
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
You can't access it. This just happened to me 2 weeks ago. I shit you not. I was tightening the bolt and the nut ripped out of the metal as it was stuck. I removed the nut but I no longer has threads to tighten the bolt back up. I had to cut out a square piece, take a big washer and cut it into a square and weld a nut on the washer. Then welded the washer back in place and fixed the problem.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 06:51 PM #7
You can see the square weld , that's the washer with a nut welded on the other side.
Old 05-15-2016, 07:12 PM #8
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
I just drilled a hole in a piece of steel plate that I cut and bent it to fit the area around the mounting spot. Then welded the nut on the back of it and welded the plate on.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 08:39 PM #9
ZionXIX's Avatar
ZionXIX ZionXIX is offline
ZionXIX is on a distinguished road
ZionXIX's Avatar
Has anyone tried using a toggle bolt anchor with a washer? I have this same problem, just wondering if there is a way to avoid welding and/or drilling.
ZionXIX is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 08:41 PM #10
Another suggestion would be cut or drill a hole on the side of the mounting point. And when you install your seat you could maybe hold the new nut with pliers or fingers and tighten the bolt.
Old 05-15-2016, 08:44 PM #11
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
This is by far the most effective and strongest way to repair this issue. I would have made my cut section a bit bigger, nbut this should hold up a long time, I'd use 1/8" plate for your patch piece.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 09:41 PM #12
The washer I used was thick as shit. Little over 1/8
Old 05-15-2016, 09:52 PM #13
fblainen11 fblainen11 is offline
fblainen11 is on a distinguished road
Happened to me on a rust free vehicle. Drilled a hole through the floor, bought a long bolt with washers. Went from a small washer and worked up to a great big washer.
Worked well and no problems. Double check there isn't anything on the underside of the vehicle. This was on my old 2wd. Not sure on my 4wd if anythings in the way
fblainen11 is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 09:58 PM #14
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
A friend repaired mine in this fashion. 3 years so far!
Originally Posted by t4r4life View Post
nice now the seat is fat chick rated
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 01:50 PM #15
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
This shit just happened to me. WTF. I don't have a welder
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Seat bolt came out ..... teachme 3rd gen T4Rs 39 08-30-2022 11:22 PM
99 3rd gen- Need plastic cover for driver seat bolt hawkcharmer Want to Buy/Trade 1 10-09-2014 12:13 AM
Wtb oak interior front passenger seat bolt cover 4runnerTiger For Sale: T4R Items 0 12-18-2011 10:18 PM
Options for Replacing a Ripped Leather Seat? Clemsonfan15 3rd gen T4Rs 12 05-28-2011 12:14 AM
driver's side seat-rail bolt cover swooopeno Problems & Warranty Issues 10 06-18-2005 10:26 PM
