Old 01-24-2015, 07:14 PM #1
triangles triangles is offline
triangles is on a distinguished road
fuel pressure check '99 4 cyl. how to?
How do I check the fuel pressure on a 4 cyl.? I have seen searching on google that there is a banjo bolt with a schrader valve on the end. Does anyone know where to get this?
triangles is offline   Reply With QuoteReply With Quote
Old 01-24-2015, 10:13 PM #2
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
Not sure if this is the right size but ...
Auto Meter 2276, Auto Meter Adapters, Extensions & Fittings | Auto Meter
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 01-25-2015, 11:35 AM #3
98Base4R 98Base4R is offline
98Base4R is on a distinguished road
According to the FSM, each injector is installed in the fuel pipe. A bolt from the fuel pipe is removed, and replaced with a special bolt that adapts to a fuel pressure tester.
Other include a Schrader test valve, to simplify getting a fuel pressure reading.
This is a link to a fuel pressure gauge that can be installed under the hood: Fuel Pressure Gauge Kit 2RZ/3RZ
At the bottom of the linked page is a replacement fuel pipe bolt, which is part of the gauge kit. If an under hood gauge is not wanted long term, a Schrader valve should be able to be adapted to the replacement fuel pipe bolt. This combo would make for a convenient test port.
02 4Runner SR5, 2WD, 250k, kid's car
98 4Runner Base, 2WD, 2.7L 4cyl, sold at 264k. Great truck, but the 4cyl just doesn't have enough power
98Base4R is offline   Reply With QuoteReply With Quote
Old 01-25-2015, 01:04 PM #4
I had that banjo bolt on the fuel rail out last week when I replaced the fuel filter. I've been chasing down a low power/hesitation and stumbling issue. Also the exhaust occasionally has a bleach like smell. I think it's just running lean but not getting anything other than occasional slow O2 error code. I had the cat pressure checked, new O2 sensors, new plugs/wires, new fuel filter chasing this down. I guess I'm down to Fuel pump and or pressure regulator.
I am going to try the banjo bolt Kball recommended. Found it on Amazon for just under $15 free ship (amazon prime). I'm pretty sure it is a 12mm banjo bolt but I don't know if the thread pitch is right. I have an oil pressure test gauge with a 1/8npt threads on it. I see no reason why I cant use this to test fuel pressure too.
Old 02-07-2015, 07:37 PM #5
well I'm back to square one. gonna start a new thread to see if anyone else has had the problems I'm having. Fuel pressure is a solid 46PSI it might sag to 45PSI WOT on the freeway. I couldn't look at the gauge very long and keep track of the road ahead. With the ignition off the pressure dropped to 34 PSI.
IIRC my Haynes manual says 38-44 psi. I don't know that I trust this and it seems like a wide range for acceptable fuel pressure. If someone has a FSM that indicates what the fuel pressure should be for a '99 4 cylinder, I'd appreciate them posting what the pressure should be.
Oh yeah the Autometer 2276 Banjo bolt pretty much matches the OEM bolt. The hole is smaller and I would have drilled it out if I were going to leave the banjo bolt in, but I intend to put the OEM bolt back in.
Fuel Pressure but no start dduncan Maintenance/Detailing 2 07-12-2014 09:47 PM
Fuel pressure test? PiTTdAwG72 Classic T4Rs 18 08-27-2013 07:40 AM
Fuel System pressure SwiftRunner Classic T4Rs 3 05-03-2012 01:25 PM
Too Much Fuel Pressure please help osborgo Classic T4Rs 6 02-10-2010 07:31 PM
fuel pressure issues again bluerunner Classic T4Rs 0 01-29-2006 01:29 PM
