10-29-2016, 07:53 AM
#16
Originally Posted by 4R#3
Here's link (with links) to glove box and ECT / Rear window bulbs, also shows bulbs for climate control backlight bulbs on Limited. Since you're SR5 with manual A/C controls, just pull the center console trim, remove the climate control section, pull a dead bulb and visit your local Toyota parts counter. Most likely special order 1-2 days to arrive.
http://www.toyota-4runner.org/3rd-ge...ml#post2510375
Thanks for the info. I'm going to pull the dash and look at these bulbs. Going to the dealership around here is probably a waste of time since they are lazy and can never find me the right parts.
2001 4Runner SR5 4x4
2019 4Runner TRD Offroad 4x4
10-29-2016, 11:46 AM
#17
You all are really going to the dealer for light bulbs? Putting a Toyota part number on XX brand bulb doesn't make them last longer. Go with a brand like Sylvania at any local parts store and I'll bet it's the same bulb (or better) that the dealer has.
10-29-2016, 10:01 PM
#18
Real Name: Scramble
Real Name: Scramble
The lighter, ashtray & glove box light up???!!!! LOL
I dont think they ever lit up on my base model, but I'll check.
I'm pretty good with up keep on stuff like that.
No need for dealer bulbs, I've had Sylvanias & Phillips last longer than OEM.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
10-29-2016, 10:09 PM
#19
Keep drinking that OEM Kool-Aid.......
BTW, you never just need one bulb. A spare or two is always good to have also in that glovebox.
11-01-2016, 04:52 PM
#20
Originally Posted by Joelev
I did this the other night and ripped off that little plastic cover/cage. I have a real knack for breaking things as I go.
There is a tab that you can use to disengage the cage cover, a locking latch. The issue that I had was trying to use my fingers to remove the bulb.........fingers are too big to grab the bulb and worse when I used latex gloves as I could barely get a tip to grip on to. Anywho, found a much easier solution for me. Remove the two screws at bottom of glove box and remove the entire glove box by sliding up and out. The bulb is in an actual 'cage' that is held in place by two tabs at either side of the cage hinge & locking tab. Pry out with a flat screwdriver and the entire cage will pop out and you can then disengage from the white wire harness that powers it from the back. My fingers would never get a grip on that bulb and I felt that if I used the pliers I was going to break it.
1997 T4R SR5 3.4L 5 speed with factory e-locker bought new with almost 1km on it
11-01-2016, 05:06 PM
#21
Real Name: James
Real Name: James
I have only one word to say about this task: (expletive deleted)
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
12-27-2016, 02:43 PM
#22
tip for opening cage
On my "98 the cage has a tab on the far side, opens very easy once you move the tab in the right direction.
02-11-2017, 08:42 PM
#23
Originally Posted by Troybylt
Didn't know I had a glove box light until after I had owned the truck for a year, I pulled the glove box out to do the taco wip mod and went "Whats this round slotted grate thing?" The bulb was a nice charred black. Next time it burns out definitely going LED. Just about every light on my rig is LED say for the headlights and dash bulbs. Though I did find some nice high quality H4 fanless headsinked LED bulbs for my Goldwing that should fit in... Hrm... I like the pure white light though it's a bit more harsh than the warm incandescent glow. I'd change my dash lights but I'm rather fond of the pale moon green. Got a HU colour tuned to match perfect.
11-10-2017, 06:35 PM
#24
Glove Box Light
Handy little tip that I read somewhere else : to get that very small glove box light out.. with one finger stick a piece of scotch tape around it and then with the “tail” of the tape pull that baby out..works great..good luck
11-10-2017, 08:26 PM
#25
I opted for a red bulb in glove box, so when my GF opens it to grab something while night driving I don't go blind.
11-11-2017, 01:56 AM
#26
FYI you can undo the little clips and pull the whole bulb assembly out and unclip the harness and take it to your bench. Much easier than trying to do it all in your floorboard.
11-11-2017, 12:48 PM
#27
This is a great tip. I was going to have my 3 year old help me pull it out with her tiny little fingers, but may try this first.
This is exactly why I love this forum already, I didnt even know there was a glove box light since mine was burned out since the day I bought it. Now to figure out which bulb/color I want to replace it with (decisions, decisions).
97 4runner limited 4wd 330k miles, elocker. Toytec coilovers, 255/85/16 BFG MT, B&M 70264, LEDs, FMU, Boss BV9358B 6.2 touchscreen, Cobra CB, Limo Tint ( Build Thread)
07 GX470 130k miles non-kdd, Old Man Emu 2in lift, 255/80/17 Cooper ST Maxx, Limo Tint (wife's)
06 Ford 500 30k miles, CVT with the 3.0, Ultraguage, Limo Tint (daily driver)
11-11-2017, 12:56 PM
#28
Maybe I just got a bad batch, but I could never get good life out of those cheap eBay white T5 bulbs. They usually go out after a few months.
11-19-2017, 10:13 PM
#29
Glovebox Light 1998 4Runner
Change out glovebox light and notice there is no button around the glovebox that turns it off & on. Discovered it stays on all the time with all the other dash lights. Does anyone else stay on all the time too?
11-19-2017, 10:31 PM
#30
Wow! Didn't even know these rigs had a glovebox light cause mine has been burnt out.
'06 4Runner SR5 V8 2WD -- Flowmaster 50 Delta Series w/ resonator delete | 265/70R17 Toyo Open Country A/T | Pro Comp Series 5044 | Black headlights
'98 Jeep Cherokee Classic -- Fender armor | 35x12.5x15 Pro Comp MT2 | 4.5" RE short arm lift | Locked | Swingout Plate Rear Bumper | Shackle Relocation Kit
