Old 01-31-2015, 04:42 PM #1
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Internal Frame Wash
I've been following all the frame rust threads and have yet to see anyone bring this up, forgive me if I missed it.
When I bought mine 2 years ago, it had an inch of dirt built up in the internals of the frame in the middle section under the doors, or between axles. The small drain holes in the frame were plugged with stones and the dirt and dust had built up over who knows how long. This mess holds the damp and I suspect contributes to the rust from the inside out. Always wet in there.
I bought a cheap garden hose and cut a 20' piece that I could insert in the frame from the back under the bumper. You can snake the hose almost all the way up to the engine from there. Then I turn the hose on full blast and let it run, slowly pulling the hose back out over the course of 10-15 minutes.
The amount of mud and pebbles I flushed out the first time had to be seen to be believed. Likely had never been done since new. I now do it spring and fall and still flush a noticeable amount which accumulated over the last 6 months. (I do drive a fair amount of gravel.)
Stick your finger in your frame in a few places to feel around for dirt. Once you have the hose it's a quick and easy thing to flush out. Certainly worth doing before you spray any rust proofing inside the frame.
Can't hurt anything anyway. Good luck.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-31-2015, 04:49 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Good advice. Best rust prevention is just awareness of the truck. If you only look under every few years you might be in for a shock.
Don't be concerned too much about the frame rust, if you notice it's all just one user bumping every rust thread in the forum's history and trying them to file a complaint with Toyota, probably to get his recalled and fixed for free or something like that. Toyota's not going to recall a 13-19 year old vehicle though.
326WHP 347TQ
Old 07-20-2019, 07:50 PM #3
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
I'm doing something similar but the frame is blocked on my truck from the rear... theres a circular bar that runs through the drivers into the passenger's side frame rails and will not allow me to get my PVC pipe in. Is there any trick or a sweet spot? For sure cannot get anything passed the rear axel let alone all the way to.the engine.
VernySanders is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 09:16 PM #4
nedceifus nedceifus is offline
Real Name: Justin Metcalf
nedceifus is on a distinguished road
Good thinking man!
nedceifus is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 09:16 PM #5
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
There will never be a 4Runner frame recall. US built frames only up to 15 years old. If you live in the rust belt holesaw larger drain holes in your frame in the low spots and coat it with something inside and out.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 02:07 PM #6
madh8er madh8er is offline
madh8er is on a distinguished road
Where did you actually insert the hose and snake it forward? I've gone under and can't find a spot to insert a hose
madh8er is offline   Reply With QuoteReply With Quote
Old 12-13-2021, 03:33 PM #7
Kanoe's Avatar
Kanoe's Avatar
Old late reply, sorry.
The frame channel is open right at the back. Access it from under the rear bumper. If you have a hitch mounted it might be hiding things.
-2001 Echo D.D.
Internal Snorkel Mod 4th gen aha2988 Off-Roading 50 05-04-2023 03:30 PM
Frame Restoration on my 97 (frame removal, repair, and upgrades) blain_gatterdam 3rd gen T4Rs 2 05-21-2015 12:17 PM
What wash and wax do you use? Teflon wash/wax? scott78945 Maintenance/Detailing 17 04-15-2014 06:53 PM
Hand Car Wash or Machine Car Wash kimboy Maintenance/Detailing 14 02-02-2005 02:01 PM
Is there an Internal Filter in the car? ssabripo 4th Gen T4Rs 2 09-21-2004 11:20 AM
