Ha, I had the same exact issue when I did mine
The sender is located in the back of the engine near the firewall, damn near in the middle
What happened was when removing my intake , I did not disconnect the sending unit, and I ripped the wire when I was lifting on the intake. From what I remmeber its a single wire I believe, and it is difficult to see because there may be some wire loom in the way that makes it hard to see. You should be able to see it by just moving wires around behind the intake/ rear of engine
Good luck, I'm almost certain you just forgot to plug it in or the wire may have ripped, it's just one wire though it should not be too difficult
Hope that helps
Loading....
