Old 02-03-2015, 11:27 AM #16
Nunyabiz's Avatar
Nunyabiz Nunyabiz is offline
Nunyabiz is on a distinguished road
Nunyabiz's Avatar
Originally Posted by TFRnoob View Post
Hello everyone,
I have a 1999 Toyota 4Runner and love it. When I bought the car I knew it had an oil leak. I would routinely check the oil and make sure it was at an appropriate level. I let my sister borrow the car for 2 weeks and completely forgot to remind her about the oil leak.
She was driving on the freeway when the oil light went on and smelt an odor she describes as burning oil or "brakes", the car rattled to a halt as she pulled over. She called me and I immediately met her with 5qts of 10W-40 oil. I poured the oil in after checking the oil level and drove to my house (about 30 miles) I noticed a drop in power and a loud-ish knocking noise particularly in the higher RPMs. I am afraid there is likely to be some major engine damage. That being said I would love some advice on how to diagnose the problem(s) the car will have and the different scenarios that are associated with the problems the car faces.
Thanks everyone!
Rich
For some reason when I read this.
All I keep seeing in my mind is this.
2002 3.4L 4X4 Sport Edition
Nunyabiz is offline   Reply With QuoteReply With Quote
Old 02-03-2015, 11:47 AM #17
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Thanks for the help everyone! Okay, so here are a few symptoms I found upon a more careful inspection that may help narrow the focus of the possible issues at hand. I suspect a cracked head or head gasket because there seems to be coolant towards the front end of the engine bay.
New symptoms are as follows:
coolant leaking from unknown source towards the front end of the engine bay.
when going in reverse, there is a pulsing.
The higher the RPMs, the louder the noise is.
No significant noise when in neutral.
Noise (clacking) occurs when turning on the car and when I am driving especially over 25mph.
Anyway, I hope this helps a little bit. I will be checking the compression later as well as checking for metal shavings in my oil later tonight. Any comments/ suggestions?
Thanks again all!
-Rich
I think you're missing the point. Compression is irrelevant at this point, you've got rod knock. A head gasket will not help. Your motor is not pining for the fjords. It is no more. It has ceased to be. It's off the twig, it has kicked the bucket, it has run down the curtain and joined the choir invisible. It is an ex-motor.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 02-03-2015, 01:55 PM #18
TFRnoob TFRnoob is offline
TFRnoob is on a distinguished road
I am having a tow truck tow it to a mechanic to diagnose the problem(s) with the vehicle tonight when I get off work. I expect the mechanic to diagnose the problem and for him to say (like everyone on this forum) that the engine is completely toast. Hopefully he can tell me specifically what broke inside the engine. When I get that information I will post and maybe either get to fixing the engine after pulling it out of my truck or look for advice on seeking a new (used) motor. I love this truck and maybe I can even give her an upgrade.
TFRnoob is offline   Reply With QuoteReply With Quote
Old 02-03-2015, 02:22 PM #19
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Originally Posted by JayRolla View Post
LOL, that is not the problem Oil is oil, it will do its job. I mean even some gear oil in the motor would have been better. No oil is not good.
As another wise man here once said, "even buttery flavored crisco would be better than nothing"
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 02-03-2015, 02:58 PM #20
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Don't waste your MONEY trying to fix it.
It would be one thing if you could do the work yourself but since you will be paying $4,000 to fix it and new-to-you USED engine with < 100K miles can be found for $1500 and installed for $750 there is no good reason to fix it. Especially since it wasn't just a head gasket or head. This was more serious and did more harm.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 02-03-2015, 06:17 PM #21
Ol'Blue's Avatar
Ol'Blue Ol'Blue is offline
Location: Mall Crawlin @ 36.1911° N, 44.0092° E,37.7460° N, 119.5329° W
Ol'Blue is on a distinguished road
Ol'Blue's Avatar
The quote I put up there is going to be what you are looking at. The shop rate will very a little bit but that install time is right out of Alldata. Everything else you will need to have done at the same time as you stuff a good used engine in it.
Compare and shop around bud and see what they tell you. If it is going to be very cheap I would run. This is not a Chevy 350 to put in a truck. It doesn't take a rocket scientist but I would not take it to some fly by night shop either.
Keep us posted man when you find the engine for the swap.
Blue
0369
“Be polite, be professional, but have a plan to kill everybody you meet.”
Gen. James Mattis USMC
"AKA Mad Dog Mattis"
Ol'Blue is offline   Reply With QuoteReply With Quote
Old 02-03-2015, 06:26 PM #22
animator's Avatar
animator animator is offline
animator is on a distinguished road
animator's Avatar
Perhaps he could fix it with a herring?
But look on the bright side, the next time you start the engine and rev it up, it may just throw a rod. Then you won't have to do any more diagnostics, because a head gaskets and cylinder compression will be the least of your worries...
2002 4runner Sport Edition
animator is offline   Reply With QuoteReply With Quote
Old 02-24-2015, 09:20 PM #23
mohjo712000 mohjo712000 is offline
mohjo712000 is on a distinguished road
I have a question I believe belongs in this thread. If you were to replace a motor in your runner , or rebuild, which would it be? Also, would say a gen 4 motor slide into a gen 3?
mohjo712000 is offline   Reply With QuoteReply With Quote
Old 02-24-2015, 09:29 PM #24
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
Welcome Michigander, No it wouldn't just slide in a 3rd gen , you can make anything work but it would be much more time and cost effective to find a good 3rd gen.
Arnezie is offline   Reply With QuoteReply With Quote
Old 02-24-2015, 10:02 PM #25
brian4t's Avatar
brian4t brian4t is offline
brian4t is on a distinguished road
brian4t's Avatar
Sorry for your troubles (OP) but this is bad news bear as you've already heard. Seek out a good used motor and go from there. The gravity of this post reminds me a thread on a different forum where the member poured brake fluid into their transmission fill, or maybe it was ATF into their oil fill. Either way it was BAD.
brian4t is offline   Reply With QuoteReply With Quote
Old 02-24-2015, 10:38 PM #26
amalik amalik is offline
amalik is on a distinguished road
Wait so... you can't drive without oil?
What a gimmick. They warned me against Toyota's.
amalik is offline   Reply With QuoteReply With Quote
Old 02-24-2015, 10:50 PM #27
Norwester's Avatar
Norwester Norwester is offline
Norwester is on a distinguished road
Norwester's Avatar
You can but it generally turns out to be a short trip.
Norwester is offline   Reply With QuoteReply With Quote
Old 02-25-2015, 01:17 AM #28
rofl. might as well put dishwashing fluid in the radiator while at it.
Old 07-03-2015, 01:21 AM #29
Question
Originally Posted by RinoRomp View Post
Same thing happend to my BMW... it was mostly the connecting rod bearings and a little extra wear on the main bearings.
I did the work for about $300, big job.
Can you pop in conrod bearings just by cracking the oil pan like a BMW?
So I have had the truck in the driveway collecting bird turd for a while and as soon as I get the nerve to start the engine replacement I get a call from my landlord requesting that I get the car working or have it towed away (a reasonable request I guess).
Anyway, I have the battery out, oil drained, coolant drained, and underpinnings removed in preparation for removing the engine. However, due to the lack of time I face now I am beginning to think this idea of changing the rod and main bearings in situ might be my only option. I am trying to find out the details on how to proceed with the bearing change by removing the oil pan.
What things should I consider before moving forward? Has anyone done this before? If not, perhaps I can document this potentially disastrous journey in a separate thread.
Old 07-03-2015, 01:43 AM #30
https://www.youtube.com/watch?v=jHeO1h3U4GE
I found a video that has some good information on bearing installation.
5vz-fe , engine , knocking , rebuild , swap
Trouble restarting when engine is hot giro Classic T4Rs 10 03-09-2014 01:33 AM
More Engine Trouble. Kill me now. 4Running Daily 3rd gen T4Rs 48 05-24-2013 11:04 AM
engine trouble ideas? mooockie 4th Gen T4Rs 19 02-22-2012 09:03 PM
'93 Engine start trouble buddha724 Classic T4Rs 2 12-11-2008 12:13 AM
? about engine trouble code 24 YotaGuy Classic T4Rs 4 11-30-2008 07:41 PM
