Old 07-03-2015, 04:34 AM #31
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Originally Posted by TFRnoob View Post
Thanks for the help everyone! Okay, so here are a few symptoms I found upon a more careful inspection that may help narrow the focus of the possible issues at hand. I suspect a cracked head or head gasket because there seems to be coolant towards the front end of the engine bay.
New symptoms are as follows:
coolant leaking from unknown source towards the front end of the engine bay.
when going in reverse, there is a pulsing.
The higher the RPMs, the louder the noise is.
No significant noise when in neutral.
Noise (clacking) occurs when turning on the car and when I am driving especially over 25mph.
Anyway, I hope this helps a little bit. I will be checking the compression later as well as checking for metal shavings in my oil later tonight. Any comments/ suggestions?
Thanks again all!
-Rich
Jap motors (basically all new motors) cant handle overheating the way old American motor's could. Your head gasket is toast as well as the bottom of the motor. If the block isn't cracked you could do a rebuild but a used low mileage engine is probably the way to go. Sorry this happened.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 07-03-2015, 04:42 AM #32
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
So I have had the truck in the driveway collecting bird turd for a while and as soon as I get the nerve to start the engine replacement I get a call from my landlord requesting that I get the car working or have it towed away (a reasonable request I guess).
Anyway, I have the battery out, oil drained, coolant drained, and underpinnings removed in preparation for removing the engine. However, due to the lack of time I face now I am beginning to think this idea of changing the rod and main bearings in situ might be my only option. I am trying to find out the details on how to proceed with the bearing change by removing the oil pan.
What things should I consider before moving forward? Has anyone done this before? If not, perhaps I can document this potentially disastrous journey in a separate thread.
It's never going to run right. The whole bottom end needs to be rebuild by a professional. Are you sure the block isn't cracked? Just pay someone to install a used motor.
____________
Old 07-03-2015, 07:56 AM #33
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
You can rebuild the motor without pulling it, but it won't save you any effort - it'll probably be harder in the long run, and you'll get frustrated and try to hurry, and you'll end up doing a shit job and have to redo it in three months anyway. I'd yank it.
If you're going to rebuild it yourself and need to buy time, yank it out of there and throw in a junkyard motor. Or buy a JDM block. Or bite the bullet and have it towed to a professional. My choice would be to find a cheap used motor, throw it in, then take my time rebuilding the original one.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 07-03-2015, 08:40 AM #34
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
^^This^^
Don't waste your time trying to band-aid it. Start tearing your engine out now while you look for a replacement one.
Or just get a whole other T4R. If the body/frame of yours is in good shape, you can still fetch some decent coin for it from a buyer up North
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Old 07-03-2015, 12:07 PM #35
mxer mxer is offline
mxer is on a distinguished road
All your oil drained in 2 weeks??
mxer is offline   Reply With QuoteReply With Quote
Old 07-04-2015, 12:04 AM #36
TFRnoob TFRnoob is offline
TFRnoob is on a distinguished road
Originally Posted by SpidermanGeek View Post
^^This^^
I like the idea of selling the body/frame. It really might be my only option at this point :/ How would you recommend going about this. I doubt throwing it on Craigslist around here would do me much good.
Thanks for the suggestion.
TFRnoob is offline   Reply With QuoteReply With Quote
Old 07-04-2015, 12:06 AM #37
HAHAHA yes, it was a tough job. No it took a while for me to work up the courage to begin the work as I know it is going to be a living nightmare.
Old 07-04-2015, 12:12 AM #38
^^This^^
You think replacing the rod and main bearings in the motor might not solve my problem? How can I tell if there is a crack in the head or block? I probably cant do a pressure test in my driveway. Is there a simpler way? I am trying to remember if there was any coolant/water in the oil and it didn't look like it.
Also, the radiator was full; although, the coolant reservoir was pretty much empty. Not sure what that implies exactly but doesn't seems good.
Old 07-04-2015, 01:44 PM #39
I think he's just wondering how the hell the engine got oil starved within 2 weeks of use if you're so religious about checking the oil level.
Sounds like the engine already had problems that needed to be addressed way before it got crippled.
Old 07-04-2015, 05:58 PM #40
You're right, it wasn't in amazing shape. There was an oil leak that needed to be addressed and i am beginning to suspect a failing oil pump. The oil light would go occasionally and there would be oil still in the truck.
Basically its toast but if i can get rid of the rod knock etc and band aid fix it maybe I can sell it "as is" and explain what happened to the truck. Perhaps someone else can address the oil leak/oil pump etc. Who knows...
Right now I am trying to cut my losses and figure out what the best path is to take financially. I don't mind working on the truck if it will get me money to buy a new truck or something.
Old 07-04-2015, 06:03 PM #41
Question Some Questions
I have a couple of questions for everyone.
1. Is it possible to replace the main bearings and rod bearings through the oil pan?
2. Under what circumstances would this be advisable (im trying to just get rid of the car at this point)?
3. Is it worth a shot if I don't find any other major defect to the engine (ie. the suspected cracked head/ block)?
Thanks all,
Rich
Old 07-04-2015, 06:14 PM #42
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
Don't bother trying to just replace the bearings. Have you even considered how you'd get the crank out and then back in? That alone should deter you. Not to mention it totally ignores any possible machine work to the bearing journals or scoring to the cylinder walls, or the fact that the entire oiling system is now full of shredded bearing material. You don't just replace the bearings and call it a day.
You really only have one option if you're not going to pull the motor. Don't put another thought, bit of time, or dollar into it, sell it as-is, and cut your losses.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 07-04-2015, 06:49 PM #43
Park's Avatar
Park Park is offline
Park is on a distinguished road
Park's Avatar
hear hear well said. I declare this thread over lol
Lifted Locked Armored
My Build: http://www.toyota-4runner.org/3rd-ge...read-toby.html
Park is offline   Reply With QuoteReply With Quote
Old 07-04-2015, 07:10 PM #44
Jdog's Avatar
Jdog Jdog is offline
Real Name: Josh
Jdog is on a distinguished road
Jdog's Avatar
Real Name: Josh
^^^ this guy nailed it.I know it's not the option you were thinking of OP but trying to bandaid the bottom end is really the worst thing. You really would be better of to peruse the craigslist.org and find a wrecked rig or a used motor. Find a fellow t4r.org member Iin your area to help and if you are not mechanical find a friend to teach and help. That is honestly the least expensive and less pain in the booty way of fixing that issue.
Jdog is offline   Reply With QuoteReply With Quote
Old 07-05-2015, 01:00 AM #45
stir_fry_boy's Avatar
stir_fry_boy stir_fry_boy is offline
stir_fry_boy is an unknown quantity at this point
Sorry to hear about the truck OP.
I'm confused on after the many people who are very knowledgeable about these trucks say "pull the motor" you just say "yeah, but . . . ".
This thread is long over. 3 pages of people telling you the entire motor is toast, not many other ways of saying it.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
stir_fry_boy is offline   Reply With QuoteReply With Quote
5vz-fe , engine , knocking , rebuild , swap
Trouble restarting when engine is hot giro Classic T4Rs 10 03-09-2014 01:33 AM
More Engine Trouble. Kill me now. 4Running Daily 3rd gen T4Rs 48 05-24-2013 11:04 AM
engine trouble ideas? mooockie 4th Gen T4Rs 19 02-22-2012 09:03 PM
'93 Engine start trouble buddha724 Classic T4Rs 2 12-11-2008 12:13 AM
? about engine trouble code 24 YotaGuy Classic T4Rs 4 11-30-2008 07:41 PM
