02-24-2015, 12:37 AM
#16
Real Name: Ted
Real Name: Ted
Originally Posted by 98WhiteT4R
Mobil 1 has both so to each his own
Thanks for the info - I just **assumed** that Mobil 1 was only synthetic and not conventional oil. I've used Pennzoil, Castrol and Valvoline and I suspect any good quality brand name would be fine.
Ted
1997 SR5 / 4WD / V6 / auto / e-locker / moonroof / bought new here in Mesa AZ / just now 109K miles / B&M 70264 transmission oil cooler / never seen road salt / always garaged / almost like new!
02-24-2015, 12:38 AM
#17
Location: US OUTPOST North 31-Mayday Mayday! We've found something!
Originally Posted by Chuckles89
Here's the info from the owner's manual.
Attachment 147194
Attachment 147195
Attachment 147196
I use Castrol GTX 10W-30 because it only gets below 0 one or two times a year. The thicker stuff is probably better for an older engine. When mine gets 400,xxx+ miles on it, I'll probably have to throw some Lucas in there to stop valve chatter and leaking piston seals.
as you should use that oil. Working & living in Mammoth Mountain for a season, I've heard some oil horror stories.
02-24-2015, 12:45 AM
#18
Thanks for all the replies - I greatly appreciate the info! I've had the good fortune of having a few 3rd gens, and put a lot of miles on my '98 in particular. I guess with all the information available these days, I started over thinking things. :0 I've mostly used Mobil 1 oils in my 4Runners - and always 5w-30 - and after reading the specs pertaining to the various 5w-30 variants currently offered by Mobil, thought I'd research a little further to see if there was one in particular which was ideal for use in the 5VZ.
1998 4Runner SR5, 5-speed
1999 4Runner SR5 Highlander, 5-speed
1999 4Runner Limited
2001 4Runner Limited
02-24-2015, 01:09 AM
#19
Real Name: Woody
Real Name: Woody
Originally Posted by acr_ted
That Tundra (-D3) filter fits ok without having to move or cut the rubber flap on the fender?
The bigger filter fits just fine. I had no problem reaching up in there by hand from the bottom. Bigger filter holds a bit more oil too. So be prepared to have enough. Last oil change mine took about 6.25qts
Or is it not that much longer? I'd think that a bigger filter would be good...but I still have 5 of the -D1 filters on the shelf, and it would take a while to use them up.
I use 10-30W Valvoline dino oil - here in the hot stinking desert I don't think I need the 5-30W spec'd by Toyota.
As I understand it, either weight is fine really. IIRC Toyota picks an oil weight that takes into account (among many other things) the MPG rating of the vehicle. So read into that what you will.
I do note that some oils come in a 'high mileage' variant - what is the difference between that and regular oil?
I believe there are just some different additives that they feel will help an older engine. I'm in the same camp you are on the Synthetic stuff and even the "high milage" stuff. My truck apparently made it through 19 years and 364+ thousand miles on plain old conventional oil—so who am I to change things.
Last time I went and tried to do something really nice for a used truck with high miles, I was rewarded with a transmission that took dump on me two days after I had it flushed.
Never again...
Ted
Me...
02-24-2015, 03:48 AM
#20
Ted
Mobil 1 IS only Synthetic, however, Mobil as a brand offers conventional oil's as well but it is called Mobil Super.
I run Amsoil Signature Series 5w-30 Full Synthetic and an extended Filter Purlator Pure One PL20195 it's about 1 inch longer than the intended filter.
I had a slight valve cover leak maybe 1 drop per minute after the first oil change to synthetic, it dropped onto the exhaust on the left side of the motor at the back but the valve cover gaskets were in need of being changed regardless.
Absolutely NO issues after changing the valve cover gaskets aside from gaining 1mpg and having a quieter engine but I wouldn't really call that an issue.
.::TRD; no, your jeep can't fallow this.
2000 Black 3.4 N/A 5 speed 4x4, most recent mod: OE e-locker setup with 4.30 gears from an auto. ARB front winch plate bumber in the garage.
She's, starting to be less stock, with about 226,428 miles as of 5/27/16.
02-24-2015, 03:56 AM
#21
Well there's your problem, you NEVER flush an auto trans, a series of drain and fill is fine, but once auto's get over 100k if they haven't been religiously flushed at their intervals or earlier than recommended every time (And it's possible even if they have) then the gunk you flush out and off the clutches is what was holding everything together. I learned this after I lost a high mile car to a trans flush. I hated that car anyway and am glad it's gone, me and Auto's have never gotten along, switched back to manual after that but I know MT isn't a viable or desired option for everyone.
Irregardless, Synth Oil is just fine in these trucks and highly recommended by my old 35y+ experience Toyota and ASE Certified Mechanic mentor in his experience he's never seen an engine in better condition as last as long by using Dino over Synth.
02-24-2015, 06:54 AM
#22
I don't think this is written in stone.
@ slapdappy
and I flushed our auto transes with 16 qts. Holding up fine so far... And I did mine when I had over 200k miles without a flush.
02-24-2015, 10:22 AM
#23
Real Name: Chris
Real Name: Chris
fwiw i use amsoil 10 40 signature in my 01 t4r with 137k and rotella 15 40 dino in my wifes 99 limited with 266k miles no issues thus far no leaks either and since I live in Florida where it is warmer than the northern states I use thicker oil also the higher miles on the 99 mean she needs a thicker oil for sure however if I l lived up north I would not use oils this thick.
02-24-2015, 12:04 PM
#24
Yeah, I don't think this is canon.
I had really dark red (nearly brown) trans fluid when I bought mine @155k, had it flushed passively with 12qts and have put 3k miles on it since then with no slippage or problems whatsoever. In fact, it shifts smoother than it did before.
Not saying it won't take a dump tomorrow, but there aren't any obvious trans problems rearing their head--especially in the month and a half since the flush.
2000 Limited 3.4L (sold at 230k *single tear*)
2007 SR5 4.0L 175k
2015 RAV4 2.5L 75k
02-24-2015, 12:48 PM
#25
"flushing" a transmission can be bad if it's a power flush, not just a fluid exchange type of flush. Some repair shops will call it a flush when it is in fact just a fluid exchange.
To stay on topic, I use mobile super 10w-30 here in AZ, temps never get below 32F, and summer has long stretches of 110F+. Also being at 260k miles seems to run a bit better with the thicker oil.
1997 4Runner Limited 4WD w/factory RR Diff Lock (4.30:1), Blue Wire Mod, KYB monomax & 'tall' coils, Falken Wildpeak AT3W 265/75 on 16x8" Raceline 887's(+1" spacing), K&N CAI, Tru-cool 4589 bypass, TB gasket mod, OEM sport hood, Satoshi style grill, steel front skid and more
"Do not go where the path may lead, go instead where there is no path and blaze a trail."
02-24-2015, 01:10 PM
#26
Banned
Banned
Veering off topic...
the friction material is cellulose (paper). my research (couple hours googling) tells me you are correct re friction material loss in high mileage vehicles that have not been flushed.
Everything You Need To Know About Automatic Transmission Clutch Disks
Transmission Flush, When and when not to flush transmission | MDH MOTORS
Powerflush | Best Western Transmission
Irregardless
my new favorite word.
@ slapdappy
yeah.
Mine had already been machine flushed by previous owner (2nd/3rd owner) at 173,000. No idea about original owner but I'll assume it was given the classic drain and refill at recommended interval. this removes some of the old fluid and leaves most behind.
mine was shifting kinda clunky so I went ahead and did the full home depot bucket style flush last year, including dropping the pan and wiping all the grey gunk (friction material mixed with metal?) out of the pan and off the magnets (metal, duh). Cannot say if shifting improved. Thought so but may have been self delusion.
Actually re-flushed recently after using a "miracle" additive, which required driving for 4000 miles then replacing. Put "miracle" on a bottle and add a few anecdotal testimonials and I'm likely to buy in. Maybe it was detergents and friction material? No idea.
About the same time I removed the rear drive shaft and cleaned the gunk (old grease) from the sleeves and seals. Pretty simple. This most likely fixed the shift clunk (reverse to drive/drive to reverse) and hard/harsh shift 1st to 2nd.
Subsequently shifts smoother, especially first to second and drive to reverse. Not perfect but no longer clunky. Def improvement.
So, reality based advice is don't do the full flush above ????? miles.
Anecdotal experience for me and amalik is positive, but we don't know the full maintenance history of our second hand vehicles.
02-24-2015, 03:43 PM
#27
It's funny how we ended up steering towards a discussion on ATF fluids. Coincidentally, that'll be my next research project. The fluid in my '99 Auto is is dire need of replacement...
Think I'll start a new Mobil ATF thread....
02-24-2015, 06:22 PM
#28
Real Name: Ted
Real Name: Ted
Me...
Thanks for the info Woody - I think I'll just keep on doing what I've been doing
Next time I need filters I'll get the larger one. I usually r&r the filter through the fender flap...with the skid plate on it hard to reach from below.
Ted
