05-25-2017, 06:45 AM
Real Name: Daddy
Real Name: Daddy
Gas tank skid plates availability?
Does anyone have a gas tank skid plate on hand they can part with, or know of anyplace with them in stock?
Mine is rusted to almost nothing and I'd like to get it replaced ASAP. Just happen to be getting other frame work done and it would be nice to knock it all out at once.
05-25-2017, 07:09 AM
This might be a solution: https://www.tacomaworld.com/threads/...closed.473229/
Try contacting RAT Products and see if he has an extra gas tank skid plate set from the recent GB or see if he can otherwise help you out. Great products.
Bilstein 5100 shocks and OME 2881/2906 springs; Tundra brake upgrade w/ SS lines front & rear; Big-3 electrical upgrade; Airaid intake.
05-25-2017, 08:47 AM
Real Name: Miguel
Real Name: Miguel
Factory or aftermarket one?
2001 Toyota 4Runner SR5 4X4
05-26-2017, 08:18 AM
Real Name: Daddy
Real Name: Daddy
Doesn't matter really, but aftermarket is always cooler
Lil Skip seems to have one ready to ship so I'm probably going with him.
Thanks for the guidance brothers!
05-26-2017, 08:21 AM
Real Name: Miguel
Real Name: Miguel
Well I got one of each if it falls through. Let me know
05-26-2017, 04:15 PM
What ever you do DONT get the shrockworks one. Long story short, your drive shaft will most likely hit it when flexing.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
05-26-2017, 08:58 PM
Real Name: Daddy
Real Name: Daddy
Wow, good to know. I was in contact with them. I'm a bit surprised, I always held their products in high regard. Still, will probably get some bumpers from them in the indeterminate future.
Real Name: Daddy
Real Name: Daddy
I definitely will, thanks. What aftermarket one do you have?
05-26-2017, 10:21 PM
Their customer service is garbage. I'll never order from them again.
05-27-2017, 07:49 PM
Real Name: Scramble
Real Name: Scramble
Wow, they were good to me when I ordered my FB. I called them with questions about the different PIAA lights & they were very helpful.
You had a good experience with the sliders though right?
But yea, I'll get a lil skips eventually.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
05-27-2017, 08:28 PM
Yeah. My OEM gas stank skid plate is dented from my drive shaft hitting it. And even the weight on the driveshaft gets caught.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
05-27-2017, 11:32 PM
Real Name: Scramble
Real Name: Scramble
It doesn't matter which skid plate you have, it's gonna hit with a tall enough lift. I cut a section of my OEM skid off with the angle grinder. No more hitting.
____________
05-28-2017, 10:42 AM
I was thinking the same. Hay it doesn't matter which skid plate you have.
I need to do that. Because it sounds so loud when your off roading lol
05-28-2017, 07:12 PM
Real Name: Daddy
Real Name: Daddy
Well, I have a bare steel plate inbound from Lil Skips, and I can't wait to get it mounted. Should be coming in Thursday.
Anyone coated one of these or a similar piece of steel meant for rough use? I'm debating what kind of coating to put on it before I bolt it on. Pics to follow
05-28-2017, 07:36 PM
Real Name: Scott
Real Name: Scott
My opinion on skids, and this is my opinion and you know what they say about opinions, is to rattle can them. If you use them, then all the $$$ you spent to get it powder coated is just going to get dinged up.
