03-01-2015, 03:18 PM
Real Name: Chris
Real Name: Chris
Foam for Sleeping in the Back
So what kind of padding are you guys using when you sleep in the back of your 4runners? I got a trip coming up and I think I will be sleeping in the back of my 4runner, seats down no special set up. I want some kind of foam or padding to sleep on but I don't know where to get it or what kind people are using.
Did the alternate search method, didn't come up with a good answer. What are you guys using?
03-01-2015, 03:48 PM
What I did was buy 1cm thick sleeping foam mats (blue in color), then I removed the cargo area carpet and put the foam down (cutting it in the right shape), then reinstalled the carpet back on top. so now I have permanent sleeping foam under my rear carpets, (which is extremely comfortable) and it also acts as a sound deadner.
ive done this to many runners and it has always worked out extremely well.
1997 SR5 4WD 3RZ/5spd. Evergreen Pearl/Oak. Elocked. 4.56 Toyota Gearing. Full body resto/Custom 3 Stage "Tri-Coat" 751 paint job. 2.5" OME lift/w Bilstein Shocks. JAOS Spoiler. Duratracs. Custom Taco Rims. EBC Brakes. SS Braided lines. Marlin Crawler Trans & parts. Marlin HD clutch. URD short shift kit. 1st Gen Shift Knobs. MStudt's endlinks. JBA SS exhaust. LCE Headers. K&N. 140A CS144 alt. Big 3/4 wiring. Hella/PIAA Lighting. 2nd Gen Map Light Mod. Custom LED switchback DRL/Turnsignals. 32" Curved LED bar. Front Tint. A/D/S/ Stereo. SoundProofed. RangeRover seat swap. 99 Clears. A/C. PWR everthing. EastWood Frame coating. AMSOIL. Custom sleeping solution.
03-01-2015, 03:57 PM
Real Name: Salman
Real Name: Salman
For my last trip I used my old Ikea twin sultan foam mattress which come in 3 pieces. I used two pieces as back seats were folded but not taken out. It was not very comfortable as I was sleeping diagonal and folded seats were still little higher than cargo area. I am 5.8.
I am using similar foam mattress for my bed as I can't sleep on spring mattress. So, I was expecting a better sleep but it was not the case. I was camping alone so I placed some important camping gear and food inside with me... not recommended for comfortable sleep.
google for sleeping platforms you will get some good results and ideas for what others are using.
2000 SR5 Burple - Expedition Build | Front bumper ARB with Superwinch| Sliders | Tepui RTT | Wilco solo Tire carrier | Cargo Box with Arb fridge slider
2020 | HONDA | CIVIC | Molten Lava Pearl | LX | 300 Miles | DD |
8 Seater minivan but with V8 | 2003 | Toyota Sequoia SR5 4WD | Guest hauler|
03-01-2015, 04:02 PM
here you can see the blue foam in the gap between the wheel well and the carpet
03-01-2015, 04:12 PM
Real Name: Chris
Real Name: Chris
This is a cool idea, but what about the seat backs? I am a bit larger than just the cargo area... haha
03-01-2015, 04:30 PM
Originally Posted by MojaveMadMan
I want some kind of foam or padding to sleep on but I don't know where to get it.
I had one of those cheap 3-piece futons with flimsy foam that I put up with for a few trips and then visited a foam warehouse type shop and had the foam replaced with high density 4" foam. Quality foam is amazing stuff. You can sample the various densities and purchase exactly the firmness you want. The good stuff will last a very long time without losing any resilience.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
03-01-2015, 05:47 PM
Real Name: Throws like a girl
Were I to not use my tent I'd put my Thermarest Trekker air mattress in there because it's easy to inflate, comfortable and easy to roll up and about the size of a Nalgene bottle when stored. Comes in various brands and sizes. It's not the cheap plan but I already have one because I'm too kinda old and creaky for the 1" thick versions.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
03-01-2015, 06:42 PM
Yeah I use air mattresses too. I got one that completely form fits the rear area, around the wheel wells with the seats down. 6 inches thick. After putting bedding on and pillow, my head actually goes over the seat backs. Super comfortable and best part is when deflated it takes up almost no room and is super light compared to a big hunk of rolled up foam. Course you do have to inflate and deflate it
03-01-2015, 06:50 PM
-Look for closed cell foam as it will not absorb water. A wet bed sucks.
-If you are traveling into a cold climate you want insulation underneath you. A couple folded blankets work. Fleece blankets are great. This is what I use for warmth - RidgeRest SOLite | Closed-Cell Foam Camping Mattress | Therm-a-Rest paired with this for comfort extra warmth Trail Scout | Self-Inflating Camping Mattress | Therm-a-Rest
-I have a cot in the back of mine. I went with a cheap, low standing, three legged cot like this - Wenzel Camp Cot - Walmart.com
This fits in the back with the rear seats folded down. I don't have to remove the lower seats. The portion of the cot just behind the drivers seat rests on top of the folded up rear seats. I can slide milk crates under the cot for storage leaving a clear "aisle" for moving around - changing etc.
I just camped in the back last week in VT with air temps at -22F at night. My boards, boots and clothes, supplies etc slide right under the cot. I stayed toasty warm.
2010 SR5, Dobinsons 300 & 505 springs, Bilstein 5100 front/rear, LED interior, Metaltech sliders, LFD crossbars, '10-'13 Trail Wheels, Toyo AT3 255/80/17
03-01-2015, 06:52 PM
LOL
my feet really don't need any foam, and since my hips and shoulders are on the foam I am comfortable
03-01-2015, 08:20 PM
Real Name: Chris
Real Name: Chris
You guys have some good methods! I really like the idea of a truck bed style inflatable air mattress. Space is an issue sometimes so that might be the ticket. I also found a foam store here in ABQ I might have to go check out!
03-01-2015, 08:54 PM
I bought an inflatable twin mattress and shoved that in the back. It's the best. They make cool truck bed ones like 2014 Warthog said that are made to go in the back of trucks/SUVs. My twin mattress was super cheap from wally world and does the job for me.
03-02-2015, 09:03 AM
I use a Therm-A-Rest basecamp XL self inflating pad, adjustable firmness and it rolls up and packs into it's own stuff sack. I actually have 2 more BNIB that I need to list for sale soon, probably $55 shipped, just need to figure out how to ship the dang things!
03-02-2015, 10:02 AM
Real Name: Chris
Real Name: Chris
I look at those things and just can't help but think; how can that be more comfortable than an air mattress? I know for hiking and stuff they make total sense, but if your sleeping in your rig are they really comparable?
03-02-2015, 11:31 AM
They are not more comfortable than an air mattress. Personally I think they are as comfortable. The main benefits of the Thermarest type mattresses are pack-ability and smaller size (and I already have one!). The air mattress is a fine option if you've got the room and don't mind the packed size. I did have a lot more trouble with leaks concerning the air mattress vs the thermarest air mattress.
You can get an inflator for either version, the air mattress can be had with a built-in version.
