Originally Posted by slides
Sitting in line at the gas station when the truck started ideling rough. It only last 10 seconds or so but felt like it was missing. No codes were thrown, anyone ever experience this.
How long since the plugs and wires have been changed? That is the first thing that I would suspect. I had the same problem and after changing plugs, wires, air filter I still had the problem. Tonight I tried the SeaFoam through the PCV tube. I used about a half of a can. Let it sit for 15 minutes and then took it out for a spirited ride. I had the RPM'S up near 5K a few times. There was some smoke, but no where near as much as some see. The idle has smoothed out and it seems a little peppier. I will see in the next few days if it stays smooth. It is still a little rough, but a tremendous improvement over what it was. What year is your truck? How many miles? IF you have a separate Idle Air Control it could be the culprit. We need more info to really determine what the causes might be.
JR
