Old 09-08-2017, 12:02 AM #151
MandAtaco's Avatar
MandAtaco MandAtaco is offline
MandAtaco is on a distinguished road
MandAtaco's Avatar
Originally Posted by phattyduck View Post
Did you just cut the head off the a bolt for the lower pin? And could you have aligned the upper joint in line with the swaybar so that it could stay a 'single' disconnect? What size is the hardware and rod ends?
I'd like to do something very similar...
Yea, the lower pin is a 3/8" bolt that I cut the head off of, and drilled a cotter pin hole into. There's enough thread that I can adjust the bolt back and forth in the A-arm so that I keep the lower rod end from bouncing back and forth. I just adjusted it until the cotter pin has just a little bit of drag against the rod end.
The hole in the lower a-arm is just shy of 1/2" from the factory, so I cut a very short piece of 1/2"OD 3/8"ID tube to sleeve the hole with before I stuck the bolt in.
You could probably rotate that upper piece and fold the link up against the sway bar, as long as your upper mount has enough room to clear the rod end while rotating. That may be something I try next time I have them off, good idea! It's pretty easy to just pull the whole link though, then I don't have to worry about something falling down and getting caught up in the suspension/brake lines.
Everything is made out of 3/8" rod ends I got off Summit, and a 3/8" fine thread, all-thread rod. A 1/2" bolt holds the upper bracket to the sway bar.
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
MandAtaco is offline   Reply With QuoteReply With Quote
Old 09-08-2017, 03:13 PM #152
Awesome. Thanks for the info. Sounds like the stock lower stud is M12, which is just under 1/2".
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-13-2017, 07:06 PM #153
frm_808 frm_808 is offline
frm_808 is on a distinguished road
Awesome man!! been meaning to make my own set as well. I replaced my bushings and seen how eaten up the rod was.
frm_808 is offline   Reply With QuoteReply With Quote
Old 09-15-2017, 10:39 PM #154
MandAtaco's Avatar
MandAtaco's Avatar
You got it, M-12. Just a hair smaller than 1/2", basically just reemed the hole out so I could use the reducer.
OverlandNV
-2004 4Runner
Old 09-18-2017, 12:26 PM #155
MandAtaco's Avatar
MandAtaco's Avatar
When I rebuilt the front suspension 2.5 years ago I put everything new in it, except the lower control arm bushings. Well, 3 were original and I had to replace one, you can read back on that mess.
Anyway I noticed lately that the front end was starting to wonder around while braking and figured it was a good time to swap them out. The OEM's are great bushings but expensive, The Daystars are easy to get a hold of, but I didn't like the idea of reusing the old metal sleeves from the factory bushings, so I decided to go with Whiteline.
Old Bushings after 220K miles.
So to remove them I first tried this method I had read someplace. Basically you use the bottle jack to put some tension on the bushing, then heat the outside of the a-arm until the outer sleeve releases. Something like this.
All I managed to do with this method Was catch my bushings on fire and get melted rubber all over the place... and probably knock a couple years off my life with the fumes. So what I ended up doing was to knock the pressed on washer off, heat up the rubber just enough so that it releases from the outer sleeve, then cut a notch in the sleeve and knock it right out. Took about 5 minutes a bushing to remove. I didn't get a ton of pics....
Molten Rubber sucks!
And Finally, new bushings in, LCA painted and looking new.
Feels pretty good now.
OverlandNV
-2004 4Runner
Old 09-18-2017, 10:22 PM #156
Sweet!! I need to do these myself. My truck wanders when going over bumps on pavement. At first i thought it could be the sway bars, but the LCA bushings were pretty bad. I was gonna grab LCA completes from Autozone with lifetime warr. and then toyota LBJ and swap em all out.
Old 09-22-2017, 11:38 PM #157
MandAtaco's Avatar
MandAtaco's Avatar
Be careful with those aftermarket loaded control arms. I put one on mine and had TONS of problems!
OverlandNV
-2004 4Runner
Old 08-12-2020, 08:52 PM #158
MandAtaco's Avatar
MandAtaco's Avatar
Bumping an old thread... but like everything I've pretty much migrated everything over to IG @nevada4wheelin . Easier to post pics and updates there.
OverlandNV
-2004 4Runner
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
