11-21-2018, 12:36 PM
Real Name: Gary Blake
Mystery Part, any ideas?
I was removing the rear driveshaft in my 2000 SR5 4WD 5spd. (Replacing rear u-joint) when this part dropped on to the garage floor from somewhere in the vicinity of the rear differential. Didn't see exactly where it came from and could not see anything amiss under there.
No operational problems have popped up since it fell off.
It's a metal cap that measures about 1/2" diameter and 5/8" long with a real fine wire soft spring inside.
Being in the rust belt doesn't help as the front edge is pretty much gone and may have helped figure out where it came from.
Diff breather maybe?
Gary
2000 SR5 4 Runner, 3.4, 5spd, 4WD
Shrockworks front & rear bumpers & sliders, Warn VR10,000S, Optima Yellow Top, Icon Uniball UCA
Toytec Ultimate Lift Kit (Soon to be replaced by Icon)
Method 305 NV Racing Wheels
11-21-2018, 12:42 PM
Diff breather?
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
11-21-2018, 12:43 PM
Originally Posted by turbo8
Diff breather?
99% sure that’s what it is.. ^
11-21-2018, 12:55 PM
That's what it was at least!
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
11-21-2018, 12:59 PM
Looks like that what it is, new one ordered, thanks for the replies
Gary
11-21-2018, 01:20 PM
You might want to check the condition of the diff fluid.
Water may have gotten in.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
11-21-2018, 01:26 PM
Thanks, will definitely be looking in to that when the replacement part comes in tomorrow morning. Its been pretty dry and cold here recently and I haven't driven it much since replacing the u-joint, will have a look at what remains of the breather and hopefully nothing got in there.
Gary
11-22-2018, 11:19 AM
Wow! That thing is in rough shape!
11-22-2018, 12:19 PM
I think that’s a Canadian dime. I got one back in change at McDonald’s once.
1990 3.0 4x4 - Sold
1997 3.4 4x4 - Sold
2008 4.7 4x4 - Only selling when I decide on a GX
2013 SR5 4x4 - Sold
11-26-2018, 12:43 PM
The new one looks a little better....
Part number is 90930-03031 if anyone is looking for one. (2000, 4WD)
Sits on the driver's side of the dif, partially covered up by the parking brake cable so that's why I didn't see it.
Easy fix to replace.
Gary
