Old 10-09-2021, 03:52 PM #16
99 Silver 99 Silver is offline
99 Silver is on a distinguished road
I am new to the T4R world. Got the wife a 99 SR5 2WD and we are loving it. Had the opportunity to ride in the back seat and was Not pleased with the ride. I believe suspension is original. Looking to replace components.. I know I should do most everything.
Its a DD so not looking to get crazy with it but Briefly looked into the Bilstien 5100s 0-2" lift(will be keeping it at 0 lift) It seems like this is a decent upgrade from stock without getting too custom.
Is this accurate?
Should/Do I need to replace the coils as well??
Probably will get new bushings and stuff.. What else should a T4R Noob but decent home mechanic know?
All suggestions are welcomed and appreciated!!
99 Silver is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 09:00 AM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Is this accurate?
If your rear suspension is bottoming out with hard hits then it's time to replace your sagging springs with new or add some spring spacers back there. Two must checks/replace are lower ball joints and radiator. If you don't know when the lower ball joints were replaced last or they look damaged/old then replace them now before they fail and cause a lot of damage. OEM is the general recommendation for replacement lower ball joints, and make sure to get the lower ball joint bolts as well. If the radiator is brown/cracking/generally old looking then it would be a good idea to replace it before the transmission cooler in the radiator fails causing coolant and transmission fluid to mix causing transmission failure in 99% of vehicles that this happens to.
Old 07-23-2022, 06:35 PM #18
KANE666 KANE666 is offline
KANE666 is on a distinguished road
Originally Posted by gamefreakgc View Post
There's a whole lot of subjectivity to what is "comfortable" to one and unbearable to others. Some have returned billsteins because they thought they were way too stiff for daily driving, and others love them.
If you are planning on lifting, I'm not sure if there's any soft shocks or struts out there. Others might chime in and be able to compare the different brands and one might be a bit softer, but for the most part your suspension will be stiff, which is what is preferred for wheeling.
If you are adding a mild or no lift, KYB's are a bit of a middle road which is what I currently have. The stock Tokico's are actually pretty good and fairly cheap to replace, you just can't lift with them since they are too short. They are the best for daily driving as far as shock absorption goes and give that "luxury" feel.
Do you have the model # for the KYB's? Thanks
KANE666 is offline   Reply With QuoteReply With Quote
Old 07-23-2022, 06:37 PM #19
Originally Posted by ajonesnv View Post
Ironically, I found the adjustable Billies to be way soft and super comfortable.
At the end of the day, if you want a off-road truck you will want the money in on a solid set of coilovers, i.e: Icon, Camburg, Fox (2.5 not 2.0), maybe even Radflo (if you have piles of cash), and so on. If you want a decent entry level I'd send you towards the OME set-up. I personally think the entry level set-ups are all comparable and you should just read through the earlier posted thread for a run down on many of the options.
Wheelsoffroad.com and sonaransteel.com can help broaden your options.
What coils are you using? Thanks
Old 07-24-2022, 02:15 PM #20
caspermike caspermike is offline
caspermike is on a distinguished road
Toytec Eibach combo. Gonna get it for mine, rode in a buddy's with the set up and it's nice
caspermike is offline   Reply With QuoteReply With Quote
Old 07-24-2022, 04:35 PM #21
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Yes, KG54317 for the rear shocks and KG9025 for the front Struts. Those models fit all 3rd Gens. They are stiffer than the stock Tokicos but only by a little bit.
https://www.summitracing.com/parts/k...nner/year/1998
326WHP 347TQ
Old 07-25-2022, 05:42 PM #22
ajonesnv's Avatar
ajonesnv ajonesnv is offline
ajonesnv is on a distinguished road
ajonesnv's Avatar
Im running Sway-a-Way coilovers with 700# springs
1999 4Runner SR5, with some stuff...
OverlandNV
You can also follow us:
Facebook OverlandNV
Twitter OverlandNV
ajonesnv is offline   Reply With QuoteReply With Quote
coils , lift , shocks and springs , suspension , third generation
Suspension suggestions kpd1999 5th gen T4Rs 12 06-10-2014 09:21 PM
no one will upgrade suspension....suggestions? palooka23 5th gen T4Rs 17 01-03-2014 06:59 PM
Looking for suspension input/suggestions... Martinjmpr 4th Gen T4Rs 0 09-12-2012 04:06 PM
lift / suspension suggestions? need help deedst4r 4th Gen T4Rs 1 08-31-2011 05:55 AM
4th Gen: Need suggestions on suspension for a 04 Kenney Engines / Suspension / Wheels / Tires / Audio / Accessories 16 01-26-2011 02:22 AM
