Well it's been a tough week. I had three death's recently, so 3 viewing/services/etc this week. Been a bit hectic to say the least.
But I did get the paint booth completed.
Couple of things I learned with some more research. You only want to put the Rust Convertor product on the rust areas and not all over everything. Although Eastwood techs said it should be fine to just spray it over everything, from my research it is best to keep it on the rust areas only.
Here's where I am at this point:
I bought a much bigger
air compressor (actually it's my Dad's birthday/father days gift, I'm just using it
) It pretty much doubles the old one we had both in tank size and SCFM.
I've sprayed degreaser on all the parts and then pressure washed everything with some simple green in the soap tank.
I rinsed everything really well and let everything dry.
I then took a air grinder with a wire brush wheel and went over everything. This was to get the major flakes of rust off and also to scuff the good paint up a bit to give the new paint something to bite to.
I sprayed everything off with the air compressor and then moved everything inside and wiped it down with acetone.
On Monday I brushed (with a foam brush) the Eastwood Rust Convertor . I did 2 coats as the bottle suggested. It turned black like it's supposed to, and after 2 days was pretty hard. The stuff isn't cheap but really seems to work well.
I am hoping to get the Eastwood Rust Inhibitor sprayed tomorrow on the frame, hitch, and all the skid plates. 2 coats is what I am going to be doing. I've never used a HVLP spray gun before, so I am hoping it comes out OK.
I'm also going to be doing the Internal Frame Coating from Eastwood tomorrow as well on the frame and the hitch. My hitch has a hole in the bottom where it rusted thru, so before I get a piece welded in there, I'm spraying the IFC in there as well.
I'll let this cure for 24 hours and then should be top coating on Saturday. I'll most likely scuff it up with a scotch pad a bit and then wipe it down with acetone before spraying the top coat.
I've changed my plan on the top coat a little. I will now be HVLP spraying
Eastwood 2K Ceramic Chassis Black instead of the Extreme Chassis Black. The 2K Ceramic is a 2 part mix and according to Eastwood much stronger and chip resistant than even the Extreme (which they said is very good). So for a couple dollars more I feel I got the better paint that should last a long time. (plus a quart covers a lot more than the 1 spray can I had bought originally. Now I should have enough to do everything for sure)
So wish me luck guys!
I'll have some pics/video to post in a couple days when I get some time.
