I have wanted to upgrade my lighting for a long time. My high beams are OK, but my low beams are just worthless. I'm using Sylivan Ultra bulbs, but they still don't give me enough light for regular driving, let alone off-road, etc.
So I got some lights from
Online-LED-Store | Emergency Vehicle Warning Lights & Offroad Lightbar and wanted to let you guys know what I thought of them.
First, they have a great selection of sizes and types. You can check them out
here.
They have great customer service as well. I had a couple of mounting questions before I ordered and they helped me figure out what was going to work best for what I wanted to do. They even had some pre-packaged wiring harnesses to make things even easier for me than running out and getting the stuff myself.
So I ended up ordering a couple different types to see which ones would work best. I ordered:
The Maverix Cubus
The Maverix 32" bar
The Cruizer 36" bar
The Maverix 6" lights
The heavy wire harness
The standard wire harness
Mounts for tubes
The Maverix series uses 5W CREE LEDs in a single row configuration, while the Cruizer series uses 3W CREE LEDs in a double row configuration. The construction of both series seems very nice with the Maverix line having a very nice slim design and felt a little more robust than the Cruizer line. Two different types of mounting hardware are included with the Maverix line, side mounts or bottom mounts. The Cruizer line has just bottom mounts, but they are quite adjustable. They all come with a 1 year warranty as well. I received everything very quickly with no damage and very nice packaging.
I'm going to try to give you guys as much of my opinion on these different series as I can so that hopefully it will help you if you are looking for lights. When I was doing research, there are just so many cheap imitation companies out there it gets very confusing pretty quick. And to be honest I was not going to pay thousands of dollars for some of the top "name brands" out there.
So let's talk the LED bar's first. I mounted them on my WMW full roof rack, basically right on top of each other. I used the same wiring, just switching the leads as I wanted to see the other light. I have some pictures I will attach of the lights on, but in all honesty they just don't do these lights justice.
THEY ARE BRIGHT!!
They have both spot and flood lights in the bar, floods being towards the outside of the bar. I really liked the 32" Maverix single row LEDs which made it more compact, and it was almost as bright as the 36" bar (even though the 36" had more than twice the LEDs). My WMW rack was actually made to fit the 36" Cruizer series and ultimately I decided that it looked just perfect mounted in the rack and the light output was just a bit more than the 32" Maverix bar.
I honestly would have rather had the Maverix single row bar, but they don't make a 36" version and the next size is a 42" which was too big to fit in the rack. But if I didn't have the rack, or was mounting this somewhere else, I would go with the Maverix series. It's just slimmer and puts out a crazy amount of light!
The first picture is just my high beams, the second is just the 32" Maverix bar by itself!!
I used the
heavy wiring harness to wire up the LED bar. I'll get some more pictures later to try to show you guys how bright it is.
