Old 05-12-2015, 09:06 AM #31
bspurs bspurs is offline
bspurs is on a distinguished road
Originally Posted by ukrunner View Post
What lift did you see?
Don't quite understand your question...If you meant what lift did I use, I used TRD Tundra coils in the front, OME 906 in the rear, Bilstein 5100s all around.
Current: 2007 4Runner Sport 4x4 V6 - 120,000 miles - stock for now...
Former: 1998 4Runner Limited 4x4 - 118,000 miles - TRD Tundra/5100 front, OME 906/5100 rear - Plastidipped exterior emblems - Black painted interior woodgrain
bspurs is offline   Reply With QuoteReply With Quote
Old 05-12-2015, 09:10 AM #32
ukrunner ukrunner is offline
ukrunner is on a distinguished road
I meant how much of a lift did you gain over stock ride height?
ukrunner is offline   Reply With QuoteReply With Quote
Old 05-12-2015, 09:18 AM #33
I gained 2" all around. To an educated eye, you can definitely tell it's lifted. To the general public, I doubt they'd notice, and that's with stock size tires.
Old 05-12-2015, 10:42 AM #34
Ok, thanks. That's too much for me. I need stock height for ease of getting in and out.
Old 05-12-2015, 11:00 AM #35
E-LOK'D's Avatar
E-LOK'D E-LOK'D is offline
E-LOK'D is on a distinguished road
E-LOK'D's Avatar
For what it's worth I'm running 285s on a hybrid 880/906 lift. The 906 rear coils are paired with OME trim packers (30mm DS and 20MM PS) to compensate for lean and the heavy bumper/tire carrier. Up front I'm running 880 coils with a trim packer on the DS and Toytec Top Plate Spacers both sides.
I've been VERY pleased with the load carrying capacity of the 906 coils. For example I had 4 heavy 265s, E load with wheels in the back last week along with the heavy rear bumper and tire carrier AND a full size 285, E load, hanging off the back with minimal sag. Also have had it loaded down many times with full camping gearing, 4 people and gear up top with minimal sag.
Running an ARB with a winch and steel cable up front as well and the 880s handle it fine with the top plate spacers.
Shameless pic...
'99 4Runner LTD, 3.4L, Auto, 4wd, SAW 2.5" C/O, Camburg UCAs, OME 906, BFG KO2 285/70, 17" FJ 8-Holes, ARB Winch Bumper, Superwinch, 4xInnovations Tire Carrier and Sliders, ARB Rr Locker, Spidertrax Spacers, Yakima rack, Hella fogs, LED Interior, Wet Okole's, more to come....
E-LOK'D is offline   Reply With QuoteReply With Quote
Old 05-13-2015, 12:25 AM #36
jgtree jgtree is offline
jgtree is on a distinguished road
I've been reading this post as I'm needing to replace shocks and possibly springs also. I need to know if this would work on a 2wd? Or is this strictly 4wd talk? What should I use to lift my rear back up?
jgtree is offline   Reply With QuoteReply With Quote
Old 05-13-2015, 09:21 AM #37
E-LOK'D's Avatar
E-LOK'D's Avatar
Suspension parts (shocks/springs) are the same between 2wd and 4wd.
Old 05-13-2015, 10:22 AM #38
MONTYMTB's Avatar
MONTYMTB MONTYMTB is offline
Real Name: Monty
MONTYMTB is on a distinguished road
MONTYMTB's Avatar
Real Name: Monty
Not necessarily... for example, Bilstein lists different part numbers for 4WD/2WD on the 4600 series - on the front anyway, rears may be the same.
'99 Limited 4WD, V6, Auto
MONTYMTB is offline   Reply With QuoteReply With Quote
Old 05-13-2015, 11:23 AM #39
honjgvb honjgvb is offline
honjgvb is on a distinguished road
What could potentially be negative about this set-up, aside from a stiffer ride (which may actually be a benefit)? It sounds like CVs and driveline should be fine. Any other repercussions to look out for, other than a sweet looking rig?
honjgvb is offline   Reply With QuoteReply With Quote
Old 05-13-2015, 11:25 AM #40
I've only had the set-up for 2 weeks, so I can't say much for what repercussions may come down the road. But regarding a stiffer ride, I wouldn't call it stiff (in any negative sense) at all. In my opinion, it feels perfect. Not soft, not jarring, but right where it needs to be.
Old 05-14-2015, 06:38 AM #41
Thanks for the reply. That's what I needed to know.
Old 06-28-2015, 01:25 AM #42
yota_addict's Avatar
yota_addict yota_addict is offline
yota_addict is on a distinguished road
I'm still curious about the 880/906 setup. I was gonna go the tundra trd route but like the price of the 880s better and would like to do 5100s and OME specific for the 4runner. Just wonder if I'll get enough lift up front with 880 to be level. Anyone with this combo chime in with a pic!
yota_addict is offline   Reply With QuoteReply With Quote
Old 10-02-2016, 09:17 AM #43
huvgti huvgti is offline
huvgti is on a distinguished road
880/906 + 5100
Hi Guys,
Quick question - I'm going to be installing the OME 880 / 906 combination with Bilstein 5100's (4Runner specific).
For the fronts, which setting is correct? Will the 880's give me the 1.5"s at the lowest setting or do I need to move the clip up on the shock? I want to make sure I don't get reverse rake. Just want a mild lift and to replace the worn stuff, also don't want to take it all apart again to adjust if I can help it.
Thanks.
huvgti is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 11:50 PM #44
O2RunnerSR5's Avatar
O2RunnerSR5 O2RunnerSR5 is offline
O2RunnerSR5 is on a distinguished road
Why not OME 880/906? Talk me out of it.
Originally Posted by huvgti View Post
Hi Guys,
Thanks.
BUMP
just ordered the 880s/906s & 5100s for front and rear. Im also wondering what perch should I set the 880s on so that it is as close to level and/or slightest front rake?
UPDATE: lowest notch for the 1.5 lift.
17 SR5
O2RunnerSR5 is offline   Reply With QuoteReply With Quote
880 , 906 , coils , ome , shocks
Talk me out if it. Or talk me into it haha poser 3rd gen T4Rs 21 12-12-2014 06:16 PM
Someone to talk to? djskorch Off Topic 23 05-28-2014 09:27 AM
Stuck at Hood - Can't Talk about it so Let's Talk about My Truck? Ryan1975 5th gen T4Rs 4 04-03-2014 01:06 AM
ATV to UTV; talk to me wnelax04sr5 Off Topic 5 10-10-2013 03:43 PM
Talk About Bad Ass! Koz All Other Vehicles 2 08-25-2007 08:25 PM
