Originally Posted by Trevor C.
Hi everyone, thanks for the suggestions.
They stay on for a brief period of time - say 10 to 20 minutes.
I've glued and sealed the lenses to the fog light body, so their shouldn't be any moisture. Plus, they blow quickly no matter what the weather is outside.
I don't know what hella micro de are. The bulbs that I put in are HELLA H3 12V 55W Yellow Star. Those should be OK, right?
Thanks again for the help and suggestions! I really appreciate it.
What I would do is unplug one of them and see if the problem is strictly one side or the other. You could also put a clamp on amp meter on the wires if you have access to one. Once you have it narrowed down it will be easier to diagnose. It's possible there's a short on the bulb inside the housing.
A 55W bulb should be drawing about 4 amps normally. If the current draw looks normal while you're sitting still, it's most likely a short inside the housing, or damaged wiring somewhere between the relay and the bulb.
