Old 03-24-2015, 11:53 PM #1
ryandc ryandc is offline
ryandc is on a distinguished road
Oil Filter Size Question
Need a little help with something.
I did my oil change (5W-30 M1 Full Synthetic) and winter->all-season tire swapout on my runner yesterday. Everything went smoothly.
I pulled off the old filter and threaded the new one on. The new one was shorter by about an inch. Both are Mobil 1 filters.
Now, thinking on it, I seem to recall that when I did my oil change last year, I came across a forum posting that indicated that there was a bigger filter compatible with the 3rd-gen 4Runner. I'm pretty sure *that's* what I purchased a year ago. Unfortunately, I can't recall what the SKU was for the part. I'd like to know what the compatible oil filters are, particularly if anyone knows offhand what the oversize M1 part is. Mine's the 3.4L engine, 1999.
Thanks for the help.
ryandc is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 12:14 AM #2
Konkordmusk Konkordmusk is offline
Konkordmusk is on a distinguished road
Well, maybe you were running the 4th gen v6 oil filter? That's what I run!
The 4Runner does not actually drive. It simply rotates the Earth to your desired position.
Konkordmusk is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 02:26 AM #3
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
The stock filter ends in number YZZD1. The one for the 4th gen ends in YZZD3. It's a little bit taller but same diameter and thread. So next time pick out a mobil 1 for a 4th gen and compare it to the one for a 3rd gen and if it looks like it'll work then give it a shot.
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 05:30 AM #4
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
I look for an oil filter for a 2005 Ford Taraus (sp?) with the regular 3.0 motor. Same diameter and threads as stock, but longer. I like running the bigger filter since I run longer oil change intervals using synthetic.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 07:01 AM #5
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
OEM Toyota filter 90915YZZD3.
Doesn't get much better than this. I use it without any problems. Order online or the dealer.
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 08:12 AM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
M1-209. Good filter.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 11:41 AM #7
I use the motorcraft FL400s at Walmart. It's the same one I put on my Saturn. Makes it easy.
Old 03-25-2015, 02:28 PM #8
cfranck1's Avatar
cfranck1 cfranck1 is offline
cfranck1 is on a distinguished road
cfranck1's Avatar
The correct Motorcraft number to use would be a FL 793.
But like others have said the FL 400S is longer in size. Plus the "S" stands for a Silicone valve in the filter, not your normal rubber one.
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
cfranck1 is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 05:39 PM #9
LeeMajors's Avatar
LeeMajors LeeMajors is offline
LeeMajors is on a distinguished road
LeeMajors's Avatar
This is for 4th Gen right? Same diameter?
I was thinking of running a bigger filter since I'm about to switch to HM Mobil1 Synthetic for the longer OCIs.
Just wanted to make sure there wasn't a prob with it seating.
2000 Limited 3.4L (sold at 230k *single tear*)
2007 SR5 4.0L 175k
2015 RAV4 2.5L 75k
LeeMajors is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 06:11 PM #10
Real Name: Woody
Real Name: Woody
It's been a while and I forget what it is supposed to be for, but it is a perfect fit and just a bit longer than the yzzd1 filter. I remove the skid plate when I do an oil change and I have no issue at all getting the filter on.
I'm sure if you google the part number or use the forum search thingy with that part number, you will see a few threads on it with pictures to give you a better idea of size.
I like them and I have no intentions of running any other type of filter on my truck.
Old 03-31-2015, 05:26 PM #11
Real Name: Woody
Real Name: Woody
I was replacing the alternator today and noticed that once the alternator and battery were removed—it was a good angle to see how the larger 90915YZZD3 oil filter sits. This should give anyone thinking about using the bigger filter a better idea of size and clearance.
Old 03-31-2015, 05:36 PM #12
psraff's Avatar
psraff psraff is offline
psraff is on a distinguished road
psraff's Avatar
Napa Gold 1516 works also. I "Think" it was for a Ford 150 back in the day... It's taller then stock.
AK to AZYota's '99 Build Thread
psraff is offline   Reply With QuoteReply With Quote
Old 03-31-2015, 11:10 PM #13
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
---Make-------Stock------Oversize
Amsoil--------EAO57------EAO34
Fram----------PH3614-----PH3600
K&N-----------HP-1002----HP-2009
Mobil---------M1-102-----M1-209
Napa----------1348-------1516
PureOne-------PL10241----PL20195
Purolator-----L10241-----L20195
Wix-----------51348------51516
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 03-31-2015, 11:34 PM #14
Neil_R's Avatar
Neil_R Neil_R is offline
Neil_R is on a distinguished road
Neil_R's Avatar
This ^^
I personally use the YZZD3 though. It fits perfectly and so does the Wix/Napa 1516.
Stock '97 4Runner SR5 4x4 Evergreen Pearl 275k mi+. Cooper Discoverer A/T3 Tires.
*UPDATED* Build thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Wheelwell Profile: https://www.wheelwell.com/profile/54...f6912f/garage/
Neil_R is offline   Reply With QuoteReply With Quote
Old 03-31-2015, 11:39 PM #15
whiskytango whiskytango is offline
whiskytango is on a distinguished road
You guys rock for handy info. We have had 3rd gens for years and I never knew this. It's handy now that we just picked up a sequoia because I can just get one filter type for both. Excellent.
And looky here, $48.50 for a box of 10. Quantity discounts.
http://www.amazon.com/gp/product/B00...A1HMPR2SUE3Q8S
whiskytango is offline   Reply With QuoteReply With Quote
filter , oil
Air filter question blademan 4th Gen T4Rs 37 03-11-2011 01:24 PM
Mobile 1 oil filter size marcus8o8 4th Gen T4Rs 9 11-28-2010 07:08 PM
AEM filter size schwalmy Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-06-2009 02:36 PM
Oil Filter question dman90012 Maintenance/Detailing 17 07-17-2004 02:25 PM
Oil filter size - V6 coolpop 4th Gen T4Rs 6 05-11-2004 10:58 PM
