Old 03-25-2015, 03:47 PM #1
DC1843 DC1843 is offline
DC1843 is on a distinguished road
Brake Upgrade Recommendations
I have a 98 Limited with the factory 6 spoke 16" wheels. I am going to have a trusted, local repair shop replace the brakes and will see if they will do the upgrade for me. I am trying to decide between the 199mm vs 231mm. I use it as my daily driver as well as towing a 5x8 enclosed trailer with 2 dirt bikes and gear throughout the Midwest. I like that the 199mm does not require the modification as the 231mm but would prefer the larger ones. Just concerned if the shop will do the mods need for the 231mm.
What are everyone's recommendation?
Also, I know the stock spare will not fit with the 231mm. Will the 199mm work will the stock full size spare?
Thanks
DC1843 is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 03:56 PM #2
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
Go 231, stock spare fitment is irrelevant since it'll fit on the rear anyway.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 04:02 PM #3
MONTYMTB's Avatar
MONTYMTB MONTYMTB is offline
Real Name: Monty
MONTYMTB is on a distinguished road
MONTYMTB's Avatar
Real Name: Monty
If you plan on keeping those wheels, I would just go with the 199 - still a big improvement over what you have, and you wouldn't have to mess with altering them. I know that some will say they've done it and had no problems, but I wouldn't. Just my opinion.
As far as whether or not the factory spare will fit over the 199, I can't remember anyone saying one way or the other. If someone confirms that it won't fit, you can find a used 6 spoke pretty cheap on CL - see them all the time.
'99 Limited 4WD, V6, Auto
MONTYMTB is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 04:07 PM #4
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
From what I know the 6 spoke wheels clear the 231mm with no issues. The shop would only need to cut some of the dust shield and that is it. Its the older 3 split spoke like I have that dont clear.
JayRolla is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 04:13 PM #5
s20004runner s20004runner is offline
Real Name: Alex
s20004runner is an unknown quantity at this point
Real Name: Alex
231mm
the only real mod is the cutting the dust shield. Everything is pretty straightforward.
My oem disc warped and had the brake shake after towing few times. I love my new 231mm.
s20004runner is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 04:20 PM #6
MONTYMTB's Avatar
Real Name: Monty
MONTYMTB's Avatar
Real Name: Monty
OP will have to confirm, but are we talking about these wheels?
If so, I don't think they will clear the 231 without modification or spacers.
Old 03-25-2015, 08:20 PM #7
Those are the wheels I have.
Old 03-25-2015, 08:29 PM #8
3rzrunner's Avatar
3rzrunner 3rzrunner is offline
3rzrunner is on a distinguished road
3rzrunner's Avatar
if you want a rotor/pad recommendation try the EBC 3GD Rotors with EBC greenstuff pads, I love them! excellent braking.
1997 SR5 4WD 3RZ/5spd. Evergreen Pearl/Oak. Elocked. 4.56 Toyota Gearing. Full body resto/Custom 3 Stage "Tri-Coat" 751 paint job. 2.5" OME lift/w Bilstein Shocks. JAOS Spoiler. Duratracs. Custom Taco Rims. EBC Brakes. SS Braided lines. Marlin Crawler Trans & parts. Marlin HD clutch. URD short shift kit. 1st Gen Shift Knobs. MStudt's endlinks. JBA SS exhaust. LCE Headers. K&N. 140A CS144 alt. Big 3/4 wiring. Hella/PIAA Lighting. 2nd Gen Map Light Mod. Custom LED switchback DRL/Turnsignals. 32" Curved LED bar. Front Tint. A/D/S/ Stereo. SoundProofed. RangeRover seat swap. 99 Clears. A/C. PWR everthing. EastWood Frame coating. AMSOIL. Custom sleeping solution.
3rzrunner is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 08:45 PM #9
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
I have those wheels and went with the 199s because the spare doesn't fit the 231s, and because I didn't like the idea of grinding the wheels. I don't do any towing, but I would think the 199s are still plenty.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 09:21 PM #10
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
Those wheels are called split 3s and as others have said, they won't clear the 231s unless you run a spacer. I think it's only a 1/4 spacer though...but I'm not positive on that.
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 01:13 AM #11
ShooterMcGavin's Avatar
ShooterMcGavin ShooterMcGavin is offline
ShooterMcGavin is on a distinguished road
I have those wheels... If I need to do brake work, my plan it to keep the wheels, do the 231mm Tundra brakes, and get longer rear wheel studs for the front. I will add a 1/4" spacer and still be able to thread the lug nuts on enough.
ShooterMcGavin is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 01:22 AM #12
96LTDrus 96LTDrus is offline
96LTDrus is on a distinguished road
Another happy 199mm owner on split spokes, I likewise didn't want the hassle of worrying about wheel clearance. Ordered rebuilt Tundra calipers for about $75 a side off ebay, put on Brembo blank rotors and Advics (Japanese supplier of OE Tundra pads as I understand). Simple, one evening, 'one beer' job.
1996 4Runner e-locked Limited
96LTDrus is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 08:13 AM #13
Thanks for the clarification.
I think I'm going to go with the 199mm's. I know the 199's have 13WE on the caliper. Is there a specific part numbers I can tell the shop? Or just tell them calipers, pads, and rotors off a 2001 Tundra?
Thanks everyone for there input
Old 03-26-2015, 10:14 AM #14
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
It should come up on the listing for the caliper what the casting is, 13WE or 13WL. They should be able to tell you easily.
Unner is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 09:56 PM #15
NJT4R NJT4R is offline
NJT4R is on a distinguished road
Last month I upgraded to the 231 because I tow a boat and the stock brakes suck under load. I found a set of '05 Tundra wheels on CL for $200 and '05 tundra calipers from a wreck for $45 each. I looked up Speedy's garage on youtube & everything works as described there and on this site.
I haven't towed yet with the 231's but I can tell already it is a huge improvement from stock.
NJT4R is offline   Reply With QuoteReply With Quote
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Rotors and Shocks Upgrade Recommendations dreti 3rd gen T4Rs 9 11-13-2014 09:51 PM
is Tundra brake Upgrade = Sequoia brake Upgrade??? infamousRNR 3rd gen T4Rs 11 02-20-2014 05:22 AM
Interior LED Upgrade - Seller Recommendations DragonRunner 4th Gen T4Rs 15 02-05-2012 01:47 PM
Looking for stereo upgrade recommendations!! taquitos43 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 11-22-2008 11:35 PM
