Old 03-25-2015, 09:41 PM #1
4Runner4TW's Avatar
4Runner4TW 4Runner4TW is offline
4Runner4TW is on a distinguished road
4Runner4TW's Avatar
Steering Rack Replaced now Steering wheel off, Please help!
So I just finished replaced the steering rack. I tied off the steering wheel to make sure it stayed straight. Got it all buttoned back up and now the steering wheel is upside down/off by 180 degrees!
I'm so frustrated that I cant think what to do to fix it to bring it close to center. I know I need to get an alignment now, is that something they can fix? I've read they can and the can't.
I marked how it was suppose to be. I'm thinking about going out there tomorrow morning and undoing it all to turn the steering wheel straight, but I'm worried I will mess with the clock spring.
I feel like there's no reason for it to be that far off when I even tied the steering wheel to the seat.
If you know anything about this subject please help I need to fixed by tomorrow..
1999 Highlander Edition, Imperial Jade Mica, Auto with e-locker, OME 906s Rear with Bilstein 5100 shocks, 5100 with OME 880 fronts, Airaid Intake, Custom cargo basket with Quickfists. Lots of mechanical 241,000+ miles
Follow the Adventure on Instagram: http://www.pictaram.com/user/twistingterrian/3486826971
4Runner4TW is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 09:46 PM #2
4Runner4TW's Avatar
4Runner4TW's Avatar
Ok I should also note that one of the OTRE would not come off the LBJ so I literally disconnected the entire steering rack and twisted it, yes the steering rack, until it came out. I then used the same process to install the new steering rack by twisting it onto the OTRE. I replaced the drivers side OTRE with a brand new one.
I counted the threads on each side and matched what it was before, but maybe the new one is a different length causing the steering issue?
Old 03-25-2015, 11:53 PM #3
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Did you center the rack before installing? Manually turn the rack all the way left, then go all the way right and count exactly how many turns. Then you go half the amount of turns back so the rack is centered. If the rack is not centered you can break the center clock spring in the steering column which not a fun cheap fix.
After thats straight you can do a driveway toe adjustment with fishing line and measuring tape and or take her to get aligned. Im guessing your rack is not centered at install.
JayRolla is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 01:12 AM #4
A.Wilson013's Avatar
A.Wilson013 A.Wilson013 is offline
Real Name: Alex
A.Wilson013 will become famous soon enough
Real Name: Alex
Hey man, @GSPRunner and I did his rack a few weeks ago and had the same issue. It's VERY easy to fix, but you'll need someone to help you out. Set aside 5 minutes to do it.
Go under the 4runner and look at where the steering column/shaft/whatever enters the rack. Now look ABOVE where it enters and you'll see two bolts running "through" the shaft, one a few inches above the other. Loosening them will allow you to press UP on the steering column/shaft/whatever enough for the teeth that go into the rack to come out. Push up on it, have your helper center the wheel, and let it slide back in. Tighten the two bolts back up.
Once you're under there all of that will be PERFECTLY clear. But if it's not pm me your cell # and I'll take a picture tomorrow.
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
A.Wilson013 is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 01:24 AM #5
4Runner4TW's Avatar
4Runner4TW's Avatar
Thanks man I have been thinking of ways to just loosen the steering shaft. I tried to loosen it myself, do you need to someone to hold the steering wheel to prevent it from turning?
Old 03-26-2015, 01:26 AM #6
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
yes to both of these. but if you did not pre-center the rack prior to installation you will need do as A.Wilson says, and seperate the input shaft on the rack for the rest of the shaft at the joint, as well as the tie rods from the LBJs once you have done this then you can center the rack by turning the imput shaft all the way to the right, and all the way to the left, counting how many turns it takes to get from lock to lock or limit to limit. then divide that number in half and turn the rack back from lock/limit that many times. once you do that straiten the steering wheel and simply reattach the the shaft to the rack and tighten everything back up. do not turn the wheel while it is disconnected as you can damage the clockspring.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 01:36 AM #7
4Runner4TW's Avatar
4Runner4TW's Avatar
Ok I've read through this a couple of times and I think I get it.
1. Disconnect the shaft
2. Disconnect TRE from LBJ
3. Use the part of the shaft that is still connected to the rack to rotate the rack from left to right, count, and reduce by half so rack is center.
4. This part I'm confused about, My steering wheel is currently upside down, so is it ok to center the wheel
5. Connected the shaft back to the rack
6. Connect OTE
7. Fluids, wheels, drive to alignment shop
My biggest issue right now and maybe the cause for all this is that I cannot get the passanger side OTRE off of the LBJ. I drove an hour to rent a tool that did not fit. I literally had to spin the entire rack off of the OTRE to remove and then spin the new one on. That was a hell of a process. I am willing to drive back out tomorrow to get the larger pulling tool to get it removed so I can get this truck going again.
Thanks everyone!
Old 03-26-2015, 09:46 AM #8
jeremyc74 jeremyc74 is offline
Banned
jeremyc74 is on a distinguished road
Banned
Why would you need to take the tie rods off the LBJ to center the rack? It's a fixed shaft between the two wheels. If the wheels are straight it's centered.
jeremyc74 is offline   Reply With QuoteReply With Quote
Old 03-26-2015, 10:13 AM #9
JayRolla's Avatar
JayRolla's Avatar
You just said exactly what we both said. LOL.
Old 03-26-2015, 10:14 AM #10
JayRolla's Avatar
JayRolla's Avatar
No not at all. If the rack is say turned all the way right when installed. Tires can still be straight and you cant turn right any. If you do this you can over extend the center clock spring. Not fun to replace at all! Usually racks come centered when new.
You must unhook the rack from the LBJ, center rack like stated above and then reconnect.
Old 03-26-2015, 10:26 AM #11
Banned
Banned
If you uncouple the steering wheel from the input shaft you can center the wheel, and center the rack, and then recouple them. You don't need to disconnect the tie rods to do that.
Old 03-26-2015, 10:47 AM #12
Real Name: Isaac
Real Name: Isaac
for several reasons. one you avoid confusion with the tires and the direction they are pointing as to where center is, plus if the tires are still attached and the rack in not centered you can hit the turning stops in the LBJs before the rack has maxed out giving you a false limit or max traverse, so you would not be able to find center. and lastly for simple ease of doing this, you dont have to turn the tires while while left and right while trying to find center on the rack -its like 100+ lbs extra you dont have to move.
yes
yes i did but i kinda barny stepped it and consolidated it -i felt it would be less confusing how it was -i mean no offence to the OP but if he had not been able to figure it out by now, then the risk was great that he would not fallow the earlier posts.
one thing i will at is you need to center the steering wheel prior to taking everything else appart -hopefully you remember what way the steering wheel turned initially to become 180* off and reverse that to center.
Old 03-26-2015, 11:14 AM #13
Banned
Banned
The issue here is the relationship between the steering wheel and the input shaft. The tires don't have anything to do with it. All you have to do is uncouple the wheel from the rack, center the rack, center the wheel, and recouple the two. If the tires are centered, the rack is centered, unless you have the adjustment of the tie rods completely wrong.
Old 03-26-2015, 11:17 AM #14
4Runner4TW's Avatar
4Runner4TW's Avatar
I did a lot of research prior to this install and somehow missed the rack centering procedure. Looking at the rack it seems centered. Both OTRE are the exact as they where when I removed the old one and the boots show equal length on each side as well.
Thank you for all the posts I get the procedure now. The biggest pain in the ass at this point is driving an hour to get the proper tool to remove the passenger OTRE. Let me recap because I think this is great information for others. I noticed a lot of people, mostly 99 as well, have been replacing their racks around 200K like mine.
1. Disconnect OTRE from LBJ
2. Diconnect the steering shaft from the rack
3. Turn the rack from lock to lock, count the rotations and half to find rack center.
4. For me, I believe i remember the way the wheel turned so I can just turn it back to center, but if you dont...
5. I read to turn the wheel COUNTER clockwise until you feel slight resistant, then turn it back 2 1/2 turns to center. This s very delicate procedure as to not break the clock spring.
6. Connect the steering to the rack. Connect the OTR to the LBJ trying to make the wheels or toe as straight as possble.
Old 03-26-2015, 11:20 AM #15
4Runner4TW's Avatar
4Runner4TW's Avatar
I feel like in my case with e OTRE being equal and the boot length on the rack equal, but just the steering is off that I might be able to just turn the wheel back to center..Which for me is clockwise.
Say the clock spring were to break, are you still able to drive the truck?
Replacing steering wheel with another Toyota/Lexus model steering wheel LexusFTW 3rd gen T4Rs 20 03-04-2021 12:24 AM
Steering Rack Replaced - Highly Recommend This! BamaDrewski 3rd gen T4Rs 14 10-04-2014 11:49 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
for those that have replaced steering rack bushings 01t4rnr 3rd gen T4Rs 19 02-20-2011 10:24 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
