Been trying to diagnose this front end noise.
It doesn't stop when I apply the brakes so I ruled that out. It only happens under load so no noise when jacked up. It gets faster as the wheel goes faster. I'm thinking it is a wheel bearing but would like a second opinion.
http://youtu.be/PTGGv5trN-g
Not the best video but if you listen carefully you can hear it. At higher speeds it's more of a rub-rub-rub.
Also it has gotten worse over the past few days so I will drive it less as possible.
I'll try and take a better video too
