Old 03-29-2015, 03:18 AM #1
4eigner's Avatar
4eigner 4eigner is offline
4eigner is on a distinguished road
4eigner's Avatar
Cone washers stuck stuck stuck
Working on the Aisin manual hub lock conversion.
Removing those pesky conewashers is proving to be quite the challenge. I've acquired a brass punch approximately the same diameter as the nut that secures the washer down. I gave them a lengthy pb blast session and soak (for days.)
Backing the nut on the end of the stud until it was flush, I gave it multiple solid wacks, working my way around to different studs around the hub. It is my understanding that this is the proper method to remove these things even when they're rusted on there good. However, the only thing I have to show for it so far is a brass punch with mushroomed ends and brass glazed nuts and stud ends.
I've also tried backing one nut against another on a stud in an attempt to unscrew the stud out of it's seat without any luck thus far.
The culprits
☆Floor Mats
4eigner is offline   Reply With QuoteReply With Quote
Old 03-29-2015, 03:23 AM #2
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Give the sides of the hub body near each stud a few solid whacks with a BFH and they should pop right out.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 03-29-2015, 03:30 AM #3
4eigner's Avatar
4eigner's Avatar
Thanks for the tip. I've already tried this without any luck. I actually gave a slight deformation/ding on the body by doing this.
☆Floor Mats
Old 03-29-2015, 03:33 AM #4
UnderFire's Avatar
UnderFire's Avatar
Yea, you'll end up denting up the aluminum with every hit it takes, but it really is the only way to get them out without it taking forever, the only other option is whacking the end of the stud with your brass punch until it finally pops loose, there's a chance it never will too.
Old 03-29-2015, 04:22 AM #5
4eigner's Avatar
4eigner's Avatar
Yeah I was afraid of that. I was looking for a way to get it done without trashing the hub body. I think I'll save that as my last resort when I'm too fed up with the other methods (probably sooner rather than later.) Next I think I'll try a propane torch to see if some heat cycles might help to break anything loose. It'll be a couple days before I can get to my torch though.
I'm certainly open to more suggestions.
☆Floor Mats
Old 03-29-2015, 08:23 AM #6
Monkeybutt2000 Monkeybutt2000 is offline
Monkeybutt2000 is on a distinguished road
I did those on my old 86' pickup. What a pain in the rear. Took 3 days of soaking with PB Blaster,then a small chisel in the gap and they came out. PITA!!
Monkeybutt2000 is offline   Reply With QuoteReply With Quote
Old 04-02-2015, 01:13 AM #7
4eigner's Avatar
4eigner's Avatar
And according to the service manual...
SA-32.pdf
☆Floor Mats
Old 04-02-2015, 07:44 AM #8
krenaud33's Avatar
krenaud33 krenaud33 is offline
krenaud33 is on a distinguished road
krenaud33's Avatar
I have removed those cone washers many times and the best method seems to be hitting the end of the studs with a brass punch. When I put them back on I use anti seize.
2000 4Runner Limited - Tundra TRD coils/adj. Bilsteins along with OME coils, 285/75/16 Kelly Safari TSR's, 4Xinnovations front plate bumper and rock sliders, RAT full skids
85' 4Runner - AP extreme lift, 37" PB Rockers, 5.29 gears, dual cases with 4.7 gear, 4Xinnovations cage/bumper/sliders, and a lot more goodies
krenaud33 is offline   Reply With QuoteReply With Quote
Old 04-02-2015, 09:22 AM #9
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Well I don't have to deal with the electrolysis you east coaster have, but I've had a few stubborn ones. My hubs are dinged up pretty bad because of it. I don't have anything new to add, but like stubborn ball joints and tie rod ends, I find the BFH is the answer, no toy hammers please!
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 04-02-2015, 10:46 AM #10
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Real Name: Charlie
Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about
Chuckles89's Avatar
Real Name: Charlie
Never done it, but this video seems pretty good
How to Remove & Replace a Toyota 4x4 Manual Locking Hub: https://youtu.be/3djqDPYI9tM
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
Old 04-02-2015, 04:37 PM #11
angus angus is offline
angus is on a distinguished road
The culprits
I'd love to see the whole project as I want manual hubs too!
angus is offline   Reply With QuoteReply With Quote
Old 04-02-2015, 04:55 PM #12
4eigner's Avatar
4eigner's Avatar
Courtesy of @Singtoe , this is the writeup to follow: AISIN Manual locking hubs
☆Floor Mats
Old 04-03-2015, 01:10 AM #13
Thanks and sorry, to answer your original question, you should soak those down with liquid wrench and come back a few hours later - then your brass drift trick should work.
Old 04-03-2015, 01:48 AM #14
4eigner's Avatar
4eigner's Avatar
Liquid wrench works better than PB blaster? Soaked them for days using that.
☆Floor Mats
Old 04-03-2015, 03:49 AM #15
I like the liquid wrench better myself but lots of people like PB - for $3 it's worth it to have both I guess.
rear hatch stuck is stuck tried everything.. tristentrd28 3rd gen T4Rs 4 11-09-2014 12:45 PM
Four hi stuck on? Winstondvm 5th gen T4Rs 2 08-18-2011 12:04 AM
key stuck marcel 3rd gen T4Rs 1 11-29-2010 11:49 PM
Stuck! dwallone 4th Gen T4Rs 21 06-20-2009 10:06 PM
Stuck in 4-low 77celi Classic T4Rs 3 12-28-2008 01:51 AM
