Old 04-06-2015, 06:58 PM #1
mirraman mirraman is offline
mirraman is on a distinguished road
How much better do the brakes get with the Tundra upgrade?
Hey Everyone,
I was just wondering how much better the brakes get with the Tundra upgrade. I just recently put a set of powerstop 231mm Tundra calipers and drilled slotted rotors. While my brakes do seem a little better, it's not the "great" improvement I was expecting. I am starting to wonder if there was a problem with the system that is not related to the stock caliper's poor function.
I am taking a trip up to northern California in a couple weeks with my wife and daughter and want the runner in tip top shape.
4runner: 1998 Limited 4x4 V6
-99 highlander lift
-265/75/16s
Here is my description of the brakes:
-They do stop.
-Seems like you need to press the pedal too hard.
-There is a sound that is a bit hard to describe coming from the drum in the back just before full stop (It's a familiar sound like when you don't push the pedal hard enough and the car starts to slowly roll forward).
-Seems like the rears aren't getting as much braking power as the fronts.
Please let me know if you have any experience with this or have any suggestions. I don't want to just start buying any and every part when it could be something simple.
Also, on a side note, has anyone ever put a 2001-2002 brake master cylinder with hydraulic brake support in a 98? was looking at my wife's 2008 and it has a very similar (if not the same) brake system under the hood.
mirraman is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 07:11 PM #2
68dave's Avatar
68dave 68dave is offline
68dave is on a distinguished road
68dave's Avatar
I installed the 199mm tundra brakes on my 00 4runner and the larger 231mm tundra brakes on my 04 tacoma with no issues. I also cleaned and adjusted the rear brakes at the same time. I noticed a big improvement in braking especially when i'm towing. Are you sure you bleed all the air out of the system?
2000 lifted 4runner-2004 lifted Tacoma TRD-Lifted 1994 3xlocked FZJ80-Stock 1995 3xlocked FZJ80-2002 4runner stock
68dave is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 07:19 PM #3
D Farms's Avatar
D Farms D Farms is offline
D Farms is on a distinguished road
D Farms's Avatar
the other difference is that the 01-02 is setup to control each brake individually, the 96-00 all have both rear brakes linked on one line. there are a lot of parts you would have to swap, i think it even controls the engine. imo not worth it. all 4runners have power assisted brakes, the 01-02 computer can apply the brakes when it detects wheel slippage, or drifting.
the main advantage with the tundra brake upgrade is increased thermal mass, so it takes longer for them to overheat, they also be less likely to warp over time.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
D Farms is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 07:43 PM #4
Definitely fully bled. Not my first rodeo replacing calipers. I just was expecting a bigger change. Anyone live local to me (Ventura county) that knows what they are supposed to feel like?
I had a 2006 Tacoma prerunner before and my wife has a 2008 4runner. Both brake systems worked much much better.
The brakes never fail. They also are not spongy. They just seem to take a bit more pressure than I would expect. Maybe my booster is starting to go.
Old 04-06-2015, 08:30 PM #5
xcmtb83 xcmtb83 is offline
xcmtb83 is on a distinguished road
What pads did you opt for? I ask because all pads are designed to favor different performance levels. For instance you may have a pad that has really good high temp fade resistance but not much initial bite. The opposite can be true too but in your case it doesn't sound like it. Just like anything else there are trade offs.
xcmtb83 is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 08:38 PM #6
DED&DED DED&DED is offline
DED&DED is on a distinguished road
I have not made this improvement to my '99 T4R, SR5--but I have noticed several posts suggesting that a higher volume master cylinder is a good idea. toyota is a fine company, but they are dedicated to engineering their products at the limits of efficiency and cost. Bigger brakes = bigger master cylinder.
edited for typo.
DED&DED is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 08:39 PM #7
Konkordmusk Konkordmusk is offline
Konkordmusk is on a distinguished road
Start with adjusting your rear brakes, so that the distance they travel to the drum surface is less and will require less brake fluid. This probably needed to be done even before the brake upgrade. Then, adjust the throw on the brake pedal. There's a jam nut and a threaded rod that feeds into the master cylinder. Adjust the rod length to be longer. This is what I did after my 231mm upgrade and I have stellar braking performance.
The 4Runner does not actually drive. It simply rotates the Earth to your desired position.
Konkordmusk is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 08:56 PM #8
These sound like some solid suggestions! I will get on it ASAP! I really don't know why making such an adjustment didn't come to mind! Thank you!!
Old 04-06-2015, 08:56 PM #9
vanion2's Avatar
vanion2 vanion2 is offline
vanion2 is on a distinguished road
vanion2's Avatar
Drilled slotted rotors have been proven to have less stopping power due to reduced surface area. Their advantage is better heat dissipation.
I know this first hand as I put a set on my MR2 and soon enough I plan on going back to blanks. And like xcmtb83 said your pads are going to have a huge effect. I don't know what pads are on mine but they bite hard and that's on stock rotors.
2006 SR5 V8
2001 SR5 4x4 Sport (sold)
1993 MR2 5SFE
2012 Rav4 4WD 2GR-FE
vanion2 is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 09:01 PM #10
Supermoney Supermoney is offline
Supermoney is on a distinguished road
I noticed the opposite.
Once we put the 231mm brakes on, we noticed a HUGE improvement. Pedal feel is perfect, stopping power is MORE than enough now. The problem with the stock 4runner brakes is that they warp way too easily. These things will not warp on this truck.
Even if you don't notice more braking power, you will notice your rotors won't be getting warped!
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
Supermoney is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 09:04 PM #11
That's weird. When I put the drilled slotted rotors on my '06 Taco, there was a great improvement in bite and stopping force.
Aren't the drilled rotors are for heart dissipation and the slotted are for preventing glaze, therefore giving better bite and performance? These have both, so I would expect an even trade off or better performance.
I currently have ceramic pads. Came with the package. Supposed to work well with the rotors.
Old 04-06-2015, 09:07 PM #12
Well, I think there may be another problem with my runner then. I replaced the calipers to improve braking. Wasn't worried about warped rotors. Think I might have to do some investigating/adjusting.
Old 04-06-2015, 09:25 PM #13
HammerHead's Avatar
HammerHead HammerHead is offline
HammerHead is on a distinguished road
HammerHead's Avatar
It's worth it and I'd do it again
HammerHead is offline   Reply With QuoteReply With Quote
Old 04-07-2015, 12:35 AM #14
ambush ambush is offline
ambush will become famous soon enough
2 thumbs up
I had a 2000 Limited, WORST front brakes when I got it. WARPED...
Tried EBC CrossDrilled and slotted. Warped after a month. Waste of money.
Called around junk yard and found a wreck Toyota Sequoia. Got the all parts. Bought Duralast Gold pads from Autozone for $50. BEST investment EVER!
Total install time 2hrs or so. It was my first time.
I say do it....
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 04-07-2015, 02:15 AM #15
Blitzkrieg Blitzkrieg is offline
Real Name: Bob/Buckwheat
Blitzkrieg is on a distinguished road
I didn't feel like spending the time on the Tundra upgrade stuff so replaced my 2002 with Disk Brakes Australia rotors.
Gotta say, they did really well.
They make the whoosh sound when stopping but heads and tails above the stock rotors and you will definitely notice the difference in stopping power.
"I speak three languages and liberal ain't one of them."
Blitzkrieg is offline   Reply With QuoteReply With Quote
Sport Edition Brakes vs. Tundra Brake (Upgrade) hawaiian05 3rd gen T4Rs 31 02-16-2019 01:37 PM
Squealing Brakes started today, let's go Tundra Upgrade. wake_rider 3rd gen T4Rs 7 09-28-2014 11:02 PM
Brakes, non-tundra upgrade question sakoluvr 3rd gen T4Rs 10 05-01-2014 01:33 AM
Tundra Brakes Upgrade Toy4Rnner General Discussions 3 10-31-2011 09:24 AM
