05-16-2006, 03:08 PM
daytime running lights
just out of curiousity... how do u disable the daytime running lights?
2000 Millenium Silver Sport Edition 4Runner SR5 3.4L V6
Engine: flowmaster exhaust 50 series, cold air intake, yellow top optima deep cycle
Exterior: crystal clear corners/bumper signals, Luminics Hyperwhites headlights/JDM yellow fogs, slimline wind visors
Interior: white indiglo gauges, iPod ready Alpine headunit, 2 10" JBL subs w/ 600w kenwood amp
05-16-2006, 03:37 PM
2006 4Runner Sport 4wd
XREAS
JVC kw-nx7000 head unit
05-16-2006, 04:14 PM
Did the above mentioned procedure on mine and was very easy. I went a step further and add male and female ends to the wire I snipped. I keep them seperated, but if I ever want to have DRLs again, I just simply plug the two cut wires together.
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
05-19-2006, 04:21 AM
is there a way to change the daytime running lights from the headlights to the fogs instead so during the day the fogs turn on as daytime running lights?
05-19-2006, 09:02 AM
best way may be to rewire them to a switch that you can turn on and off at your discretion.
XREAS
05-20-2006, 01:31 PM
For my car, a 2000 runer, take the little compartment underneath the hand brake. Underneath, there is a switch. what you need to do, is you need to loosen off the screw that holds it in and rotate it 90 degrees so that the handbrake no longer hits it. You can not disconnect it becaseu the screw is the ground and the gound is through the chassis.
2000 Toyota 4Runner SR5 w/ 3.4 L V6
K&N FIPK air intake system
H4 HID Conversion headlights(6000K)
Piaa LED Fog/driving lights
Clear front corner/turn signal lens covers
Black/Carbon Fiber altezza tail light covers
"Toy Yoda" badge
Full Custom Flowmaster Super 40 Series Dual Exhaust
Carbon fiber "B" pillars
White dash gauges
LED exterior lights (all of them)
LED slow flasher unit for turn signals
Blue LED windshield washer nozzles
285/75R16 Bridgesone Dueler A/T
Had a Blue Undercar kit, but broke it off-roading. oops!!
05-21-2006, 04:45 AM
Super Moderator
Super Moderator
Just do the fog light rewire and turn them on when you want to.
http://www.yotatech.com/showthread.php?t=75177
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
05-21-2006, 09:01 PM
why would you want to disable them ?
is there a practical reason for that, cause it seems that there is a practical reason to have them on.
so im curious...
05-21-2006, 10:39 PM
Super Moderator
Super Moderator
so im curious...
When using aftermarket bulbs which are a bit more pricey than the OEM version the DRLs go through them too quick and the reason DRLs are used it's too improve your visibilty fro other drivers but I thinks it's more helpful at dusk and dawn when people whould have their lights on anyway but the government mandated DRLs since there's alot of people that don't know when to turn their lights so they are on all the time now.
2010 Lexus RX350
05-22-2006, 08:32 AM
so im curious...
A couple reasons why I disabled them:
First, I run PIAA headlight bulbs and I didn't want to shorten their life by running them all the time. 2nd, I drive the freeway A LOT. It's nice to be able to tell oncoming traffic a cop is waiting on them, telling a trucker it's okay to move over in my lane and when someone's doing 60mph in the fast lane, it's nice to be able to flash your lights at them to MOVE OVER. (sorry, this happens to me a lot.) Third, I take trips with others and when a cell phone won't work, it's nice to be able to flash your lights at them to pull over.
05-22-2006, 09:15 AM
First, I run PIAA headlight bulbs and I didn't want to shorten their life by running them all the time. 2nd, I drive the freeway A LOT. It's nice to be able to tell oncoming traffic a cop is waiting on them, telling a trucker it's okay to move over in my lane and when someone's doing 60mph in the fast lane, it's nice to be able to flash your lights at them to MOVE OVER. (sorry, this happens to me a lot.) Third, I take trips with others and when a cell phone won't work, it's nice to be able to flash your lights at them to pull over. [/B]
drl's dont impede your use of the highbeams...?
im confused?
DRL's do shorten bulb life for a lot of aftermarket bulbs, but I have to say I have had my sylvania silverstars in for coming up on a yr now, I have DRL's and theyre still perfect.
XREAS
05-22-2006, 09:23 AM
im confused?
That's true, but for some reason people tend to respond quicker if they see you flicking your lights at them and can see a contrast in light. Meaning, "On, Off, On,Off". With DRLs, there's not that much contrast of light.
Who knows, maybe it's a Southern thing, but people sure can't drive the freeways good at all around here.
On the headlights, I would hope my PIAAs last a year, but I'm wanting them to last a lot longer than that.
08-09-2006, 02:20 PM
k... so i see what youer talking about... only problem is.... i cant get to it.... i know u could take it apart but unfortunately i cant unscrew the area by the seats because they are in the way if you know what im talking about.... is there a way to unscrew it so i could take it apart w/o taking out the seats... only other way i could think of is getting a smaller screwdriver but i dont have one.... HELP?
08-09-2006, 03:57 PM
If you can go to a company like WalMart and by the really short interchangable screw driver tips. then purchase a 1/4 combination wrench and you can unscrew teh sensor there. THe other way, is to try and find a really stubby phillips screwdriver.
"Toy Yoda" badge
White dash gauges
08-09-2006, 10:13 PM
I just unplugged the DRL module under the hood. Took like 5 seconds, and to get them back, I just plug it back in.
Have fun with whatever the hell you guys are doing though!!!
1997 4Runner Limited
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
