04-09-2015, 07:44 PM
Door lock actuator motor
Does anyone know what the part number is for the actual Mabuchi electric motor inside the door lock actuator ?
I think the correct part number is FC-280PC-22125 or FC-280PT-22125
anyone have experience with this ?
This is for a 2000 4Runner.
2011 4Runner
04-23-2015, 09:10 AM
this is the very same question I've been asking around, with no luck. have you solved the mystery? thanks!
04-23-2015, 09:14 AM
Banned
Banned
Which door and what year?
04-23-2015, 09:38 AM
Real Name: Throws like a girl
#FC 280PT-22125 and I bought 4 of these little buggers for 19.95 shipped. Make sure they have a collar, mine came from MOPS Electric off Ebay.
pics and more infos
posts 1463-1476
habanero's 1996 4Runner Build-Up Thread - Page 74 - YotaTech Forums
Edit: another pic
And this pic shows the shaft you need, kind of short with a collar:
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
10-13-2017, 02:42 PM
I am thinking of tackling the actuator issues as well.
How did this solution work for you? Did the motors correct the issues with your actuators?
Also, what year is your 3rd gen 4Runner?
Appreciate any input/feedback you could provide! Thanks in advance!
10-13-2017, 03:21 PM
There are a few issues that can cause door lock problems, three that I can remember seeing, this being one of them.
For me:
the front left and rear right door locks got weaker and weaker, and it seemed to be temp related. You could see them jump, but it took extra tries for them to unlock and sometimes they couldn't unlock at all.
1996, daily driver so locked and unlocked multiple times nearly every day.
it corrected the issue described above
did this Sept 2013; 4 years later they still work perfectly
10-13-2017, 04:10 PM
For me:
I want to thank you for the response! Clearly, many of us on this forum that LOVE our 3rd gen T4R's will (or have or have encountered) this issue at one point or the other. I am about to put in an order for four (4) of the actuator motors and replace all of them on my 2000 T4R rig. Knowing you have enjoyed success with this approach gives me confidence this is the RIGHT WAY to go.
One last detail question: Do I need to order the motors with the brass end/coupling?
Thanks again!!!!!
10-13-2017, 06:47 PM
Thanks again!!!!!
Awesome, if the actuator motors are your problem then replacing them should fix it.
Note: My right front and left rear are still original and working fine....if you've got 4 bad ones- especially all of a sudden- you will want to research other possibilities too.
YES, get the motors with the short shaft and the brass collar. The number I gave is searchable but do make sure they are right- pic above and in my build thread, link above. There's a how-to there as well. Just remember I'm not a mechanic, nor do I play one on tv. I believe Iball engineer has a write-up here somewhere too.
I think MOPs is still around on ebay, but my old link might not work.
08-15-2018, 04:29 PM
Do the door actuator assemblies or the door actuator motors differ by year?...
or is everything the same (assembly and motor) for all years? (1996-2002).
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
08-16-2018, 11:14 AM
I used mine on the 96, front and rear were the same.
I haven't had to do the 99 yet but I think Iball engineer did something around that year with a nice write up.
Don't have much more than that. Toyota showed the lock actuator number for the rear to be the same for all the 3rd gens, don't know that they'd swap motors.
I do know the 4th and 5th gens are different.
08-24-2018, 11:43 AM
This seems to be the current link for one from MOPS: https://www.ebay.com/itm/271583579344
08-24-2018, 01:00 PM
Originally Posted by Spktyr
I purchased these from MOPS on EBay: 4X FC-280 Motors with Collar - Car Door Lock and Mirror Motors - FC-280PT-22125
I could not be more satisfied! Changed all the motors out and now the door locks close like a vault. HIGHLY RECOMMENDED!
Changing the actual motors out takes no time at all. It is getting the actuators out of the door, opening them up and reinstalling them that take the TIME!
08-25-2018, 01:54 PM
Bama - I am getting ready to do this job on a 4th gen T4R (2006) and ordered the following given discussion on that forum. Same motor but they do not have the collar....did you need it?
https://www.ebay.com/itm/4-x-10mm-FL...72.m2749.l2649
Buckaroo
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
08-25-2018, 02:29 PM
Originally Posted by Buckaroo
Buckaroo, I definitely needed the collars! I have no idea about a 4th gen though. For me (to make sure) I went to a Pull-a-part yard and pulled the door lock actuator off a junk vehicle. I opened it up and the motor had the collar. This was just to make sure I needed them. Perhaps someone with a 4th gen (who has done this) can let you know for sure. Good luck man!
