Originally Posted by TheDurk
I assume you meant output here where I bolded. If so, then yes. However the ground (from the speaker I assume), I would ground to the case or any ground lug of the radio. Better chance to avoid a ground loop hum.
Actually if the external speaker has 3mm plug it could be either mono or stereo. In reality you only need two of the 3 wires if it is a stereo plug. The ground is a common ground and the other two are left and right. If it is a mono, like a CB speaker, it probably only has two wires. You could try grounding to the case as see what happens, since El Durko is quite knowledgeable about electrefonics,
. I usually defer to
TheDurk
when it comes to 3rd gen stuff but he might be off here
, never can tell.
Try both cookies, and call us in the morning.
