Originally posted by statechamp02
while i was jacking wiht the air elbow thats in my fender so i can do the mod i kinda f'd up meaning i cant get the elbow out from the fender what can i do plz help thanks
Not sure if there are any differences, but I just did this mod this past weekend on my '02 T4R. Took me less than an hour. Are you forgetting to remove the bolt that's hidden in the fender wall that holds the other piece in? You have to remove a few of those plastic clips and then peel back the plastic liner to access this bolt. Once removed, I pulled the remaining part of the elbow out through the same inlet. Hope this helps. Check out this link for more info:
http://www.yotatech.com/showthread.php?t=75165
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
