Originally Posted by Bad Luck
What's the CEL code? I've seen similar behavior from a bad evap purge solenoid on other vehicles, but I'm not familiar with our evap system.
You could remove the vapor line from the EVAP and see if it stops. It should have a liquid check valve.
How full do you fill your tank?
