04-28-2015, 08:36 PM
Real Name: Brian
Real Name: Brian
Oil dilemma
Has anyone used the Mobil 1 high mileage synthetic in their 4runner? My 01 is due for an oil change and it has 190,000 miles on the clock. I have used the Toyota certified oil from the dealer for almost 5 years now. The 4runner doesn't leak nor use/burn oil. I have been looking at the Mobil 1 only because of the reputation of Mobil 1 synthetic. I also only use the Toyota oil filter exclusively, not switching from that at all. What are your thoughts?
You can't fistfight tyranny!
04-28-2015, 08:43 PM
I use Mobil 1 synthetic extended performance 5W30 and have no complaints I change every 5000 miles and no leaks.
I buy it at Walmart under $27 for 5qt
http://www.walmart.com/ip/Mobil-1-5W...5-qt./17128876
04-28-2015, 08:45 PM
Real Name: Robert
Real Name: Robert
This question is almost like who's political beliefs are the best, or which religion is better. You'll get a wide range of opinions.
Personally I go with Mobil 1 or Bosch oil filters, and I use the Mobil 1 "gold cap" synthetic stuff... the stuff that's supposed to be good for 10,000 or 15,000 miles or something. Only leak I had was when I realized I hadn't tightened down my oil filter tight enough. My fault completely lol.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
04-28-2015, 09:02 PM
Real Name: Jeremy
Real Name: Jeremy
I use rotella T6 5w40 with wix filters. VERY confident in the oil. Research it / try it and see what you think.
04-28-2015, 09:13 PM
Real Name: Brian
Real Name: Brian
Yeah, I know that it is a matter of opinion and I hope I don't get flamed but with my baby coming up on 200,000 miles, I just want to do what's best to get all the miles I can out of her.
04-28-2015, 09:23 PM
I always wonder what flavor the certified Toyota oil is . I do know it differs per region, maybe even location.
Regardless, pick up some 5w or 10w-30 in M1 HM and enjoy. Great oil. The Mobil Super High Mileage is excellent as well.
04-28-2015, 09:27 PM
Real Name: Jeremy
Real Name: Jeremy
A lot of it is opinion, iron & steel religion and even some politics. But the facts / test results and what is in oil are easy to measure and quantify. I am not saying to not go with mobile 1 in any form. Just offering what I would use and do use.... have had outstanding success with, keeps your engine clean and has the right ingredients such as a high zinc content which keeps your engine spinning for a long, long time.
Another filter I like and would recommend would be pure one / however I usually just go wix.
04-28-2015, 09:34 PM
Real Name: Woody
Real Name: Woody
If my engine was torn down and inspected, I'm sure it would not be all spiffy looking and clean like some of the engines I see here. That said, my trucks PO never used anything but the cheapest oil at the cheapest of oil change shops around. Basically, conventional oil got my truck to 369,949 miles and she runs freaking great too.
I'm not going to bother with synthetics for three reasons:
1) I can't afford to throw money on the synthetic train.
2) If it made it this far without synthetics...who am I to mess with it.
3) I don't need any new or worsening oil leaks since I need to replace leaky valve cover gaskets one of these days.
I do my own oil changes and I use Valvoline conventional oil. I now run the bigger OEM oil filter though; I also change the oil approximately every 4k.
Basically, it's not broke—so I'm not going to try fixing it.
04-28-2015, 09:59 PM
i use mobile 1 syth high mileage
04-28-2015, 10:03 PM
Real Name: Charlie
Real Name: Charlie
Amen brother!
Originally Posted by STX4Runner
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
04-28-2015, 10:34 PM
The good 'ol 5VZ does not care what oil you put in it as long as it meets or exceeds factory specs.
Mine has been on regular Castrol for it's whole 270k (I know the prev. owner) and is still clean and in great shape.
Why?
Because it's been changed frequently and high quality filters were used.
That's all there is to it.
Stock '97 4Runner SR5 4x4 Evergreen Pearl 275k mi+. Cooper Discoverer A/T3 Tires.
*UPDATED* Build thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Wheelwell Profile: https://www.wheelwell.com/profile/54...f6912f/garage/
04-28-2015, 10:55 PM
Real Name: Instagram: briansd_97r
well hey if it has worked perfectly until now @190k miles then of course you should change it up.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
04-28-2015, 11:18 PM
Real Name: Chris
Real Name: Chris
And always remember boys and girls, say no to...FRAM.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
04-28-2015, 11:26 PM
Real Name: Greg
Real Name: Greg
I use this with an OEM filter.
Visit the SURF RUNNER 2.0 Build Thread...
http://www.toyota-4runner.org/3rd-ge...mited-4wd.html
04-28-2015, 11:46 PM
Real Name: Chris
Real Name: Chris
My mechanic has twisted my arm. Next oil change is going to be Rotella. Hate Wal-Mart but my mechanic said that's the cheapest in town.
He laughed at me for buying high mileage oil for it when I had him tear through the vehicle after I bought it.
