Originally Posted by phattyduck
Those wheels should fit just fine - they will likely have a slightly higher offset (suck the wheel in a bit), but unless you are running oversized tires that won't be an issue.
Thanks. I should have clarified that my driving rims are OEM aluminum. The tire on the spare that I will get is slightly narrower, with a higher aspect ratio, but I calculated the overall diameter to be close enough to be used for a spare.
Long story how I got here now to replace this spare, but it has been bugging me for a while, not having a spare that is safe and reliable.
